When I tried to open the .ai file in Adobe Illustrator 10, it displayed an error which states, " Adobe Illustrator file format is having difficulties "
What should I do for the problem?
Try DVDFab and download streaming video, copy, convert or make Blu-rays,DVDs! Download free trial !
Illustrator 10 is from 2001. It is very likely your file was made on a newer version.
https://helpx.adobe.com/illustrator/kb/troubleshoot-damaged-illustrator-files.html -
If you want to zip it up and upload it to a free hosting site, I can convert it to an older illustrator format for you . But you might lose some features and formatting due to the conversion to an older .ai version. But I won't spend the time fixing or editing it for you. PM me with the link if you don't want it public
There may be a TMP file in the same folder, you can try renaming it to AI and see if this opens. Helped me on a couple of occasions but also has not worked in the past. If it useless, there is a good program: Illustrator Fix Toolbox https://www.fixtoolbox.com/illustratorfix.html
Adobe Flash Media Server 4.5 F4M Question
By dchadd in forum Video Streaming DownloadingReplies: 0Last Post: 26th Feb 2015, 19:29 -
SONY VEGAS / Adobe Premiere - Font and FX Templates Question
By PantherX in forum Newbie / General discussionsReplies: 3Last Post: 9th Nov 2013, 16:34 -
Super Easy Question about COMPRESSION USING ADOBE PREMIERE PRO CS5
By BronProductions in forum Newbie / General discussionsReplies: 2Last Post: 23rd Mar 2012, 19:48 -
Exporting Premiere Pro CS4 Project - Adobe Media Encoder question
By schmickers in forum Authoring (Blu-ray)Replies: 1Last Post: 27th Jan 2012, 19:51 -
Adobe Encore DVD Question...
By sdsumike619 in forum Authoring (DVD)Replies: 10Last Post: 26th Aug 2011, 06:46
