  1. Hi but sorry I'm_a_cAt
    please I wonder
    is there a way to concatenate more .mxf files
    C0001.mxf
    C0002.mxf
    C0003.mxf
    C0004.mxf
    C0005.mxf
    C0006.mxf
    C0007.mxf
    and so on
    so that a unique .avs open all thsi .mxf files with the audio part of each file?
    thanks
    ps: if a .mxf file does not have the audio part, avisynth should put a silence in audio but the sync audio/video for each file have to be keep, thanks
  2. Code:
    file1 = SOURCEFILTER("C0001.mxf") #replace "SOURCEFILTER" with the source filter of your choice
    file2 = SOURCEFILTER("C0002.mxf")
    file3 = SOURCEFILTER("C0003.mxf")
    file1++file2++file3
    Note that you can run into memory problems because more source filters = more RAM needed. So you may need to append them before loading them in AviSynth. (Using ffmpeg/fmbc?)
    http://avisynth.nl/index.php/Splice
  3. Code:
    SetMemoryMax(16)
    LoadPlugin("v:\automazioneclip\avisynth\plugins\LSMASHSource.dll")
    file1 = LWLibavVideoSource("W:\brisighella\C0060.MXF")
    file2 = LWLibavVideoSource("W:\brisighella\C0061.MXF")
    file3 = LWLibavVideoSource("W:\brisighella\C0062.MXF")
    file1++file2++file3
    mmmm yes I have try this but there is no audio :=(
  4. mmmmmmmmmmm
  5. SetMemoryMax(16)
    videofile1 = LWLibavVideoSource("W:\brisighella\C0060.MXF")
    audiofile1 = LWLibavAudioSource("W:\brisighella\C0060.MXF")
    file1 = audiodub(videofile1,audiofile1)
    videofile2 = LWLibavVideoSource("W:\brisighella\C0061.MXF")
    audiofile2 = LWLibavAudioSource("W:\brisighella\C0061.MXF")
    file2 = audiodub(videofile2,audiofile2)
    videofile3 = LWLibavVideoSource("W:\brisighella\C0062.MXF")
    audiofile3 = LWLibavAudioSource("W:\brisighella\C0062.MXF")
    file3 = audiodub(videofile3,audiofile3)
    file1++file2++file3
  6. can I tell to avisynth:
    if the videofile or audiofile part does not have video (or audio) part, please insert black (video) or silence into the gap?
  7. There are functions to create black video and silence. I'm sure it's possible to make it a bit automatic but I'm too lazy to give you an example. Try a search.
    http://avisynth.nl/index.php/BlankClip
    http://avisynth.nl/index.php/Tone
