I'm trying to cut an mkv video file with Avidemux 2.6 and I don't want to re-encode. I want an exact copy, so I used:
Video Output - Copy
Audio Output - Copy
Output Format - MKV Muxer
I selected A and B (as In and Out keyframes) but when I try to save the video I get this:
The video is in copy mode but the cut points are not on keyframes.
The video will be saved but there will corruption at cut point(s).
Do you want to continue anyway ?
I want the cut points on keyframes without re-encoding, what should I do?
cutpoints are on the up and down arrow keys. you can see what kind of frame I P or B ons screen.
If you use the left and right arrowkeys you get the P and B frames as wel.
Make sure you always end on a I frame by using the UP and Down arrowkeys
FFmpeg, and keyframes in vide files
By 2di in forum Video ConversionReplies: 2Last Post: 31st Jul 2020, 01:36 -
How to get video keyframes by command?
By xicudiz in forum Newbie / General discussionsReplies: 0Last Post: 28th Nov 2013, 03:48 -
Modify a FLV file so the keyframes are not so far apart?
By gumbygum in forum Video ConversionReplies: 21Last Post: 17th Jul 2013, 16:34 -
Keyframes in MP4
By yepyep in forum Video ConversionReplies: 10Last Post: 12th Dec 2012, 00:28 -
Total keyframes?
By anonymous_whatever in forum Newbie / General discussionsReplies: 41Last Post: 12th Feb 2012, 10:33
