I'm looking at buying a new PC that I'll use in large part to rip my DVD/BluRay collection. As such I'm trying to understand what's important when ripping a disc, is it the GPU, or CPU speed, memory, disk read/write speed? Obviously I'm sure each of the aforementioned plays some part, however I'm trying to follow what resources are being used when ripping a disc.
information wants to be free
Just ripping doesn't require much. Just a fast blu-ray drive and a HUGE hdd for blu-ray rips.
But do you want to shrink/reconvert your video? -
CPU speed and number of cores are the most important hardware considerations when converting with Handbrake. The X264 encoder is fairly well optimized for multithreaded operations, so get a quad core cpu at least.
I have a couple of Pioneer BDR-209's which are the fastest I've tried for ripping my BDs to a hard drive for backup.
It's too hard on the drives to convert directly. I use AnyDVD HD running in the background for decryption.
I use 1.5TB WD hard drives. For converting to MKV/AC3 video, I have a AMD FX-8350 8 Core CPU 4.2Ghz CPU.
This information is in my Computer Details.
Most times I use RipBot for the MKV conversions, sometimes Vidcoder. Both can batch convert from the HDD files.
It takes about 2 hours or a bit more for each conversion, but I like the quality.
I convert to a 8GB MKV for convenience for secondary backup to BD data discs. Primary backup is to my video server for playback.
For DVD conversions, also to MKV/AC3, I just use VidCoder and batch them. Takes about 20 minutes for this conversion.
I use CQ settings of 18.5 and constant framerate. Video filters of Detelecine and Decomb. Most everything else at default.
I end up with file sizes of 1GB to about 3GB, depending on the source DVD.
In my system, the GPU doesn't have much to do with the conversions. RAM either. I use about 2 - 3 GB RAM for encoding MKV,
but it does use all 8 cores at close to 100%.
If you are considering building a PC or having one built, this is a link to the build of the one in my Computer Details:
https://forum.videohelp.com/threads/360866-Motherboard-CPU-RAM-upgrade-to-8-core-AMD-CPU?Last edited by redwudz; 10th Mar 2016 at 11:02. Reason: Added DVD information
Ripping Bluray disc by scaling bitrate
By zeusfriends in forum Blu-ray RippingReplies: 30Last Post: 4th Nov 2014, 13:23 -
I am having a problem ripping a bluray disc
By laserguy100 in forum Blu-ray RippingReplies: 2Last Post: 6th May 2014, 18:01 -
Copying & ripping my blu ray movie then burning it onto a blank bluray disc
By chris_2012 in forum Authoring (Blu-ray)Replies: 18Last Post: 22nd Mar 2013, 10:43 -
Ripping FULL HD 3D Bluray from my 3D Blu Ray disc?
By chuckbass in forum Blu-ray RippingReplies: 15Last Post: 4th Sep 2012, 23:58 -
h264 encoding does not use all system resources
By sharkbite in forum Video ConversionReplies: 3Last Post: 28th Feb 2012, 20:16
