Results 1 to 10 of 10
  1. Hi
    I've downloaded an ep from korean drama with chinese subtitle, it format's MKV but when i try to extract subtitle by MKVtoolnix in extracting section it only gives me Video and audio but not subtitle, would somebody help me? and is there any other way to extract subtitle?
    thx
    So mkvtoolnixgui does not show any subtitle track? Maybe they are burned in the video. Can you turn off/on the the subtitle ?
    Try also gmkvextractgui.
  3. Originally Posted by Baldrick View Post
    No, it doesn't
    If they're burned then i can't extract them? i tried the other one n it's the same result
    You can try an OCR subtitle software like Subrip. But I don't think it supports chinese subtitles though....
  5. Originally Posted by Baldrick View Post
    Oh thx so much, btw is there any program that can reads chinese\korean words from video? or at least gives me the timing and i can subbing?
    thx again bro
  6. Can You upload a short clip?
  7. Originally Posted by Bonnevue View Post
    For what?
  8. Also first check if MKV have subtitle with MediaInfo
    for example this MKV have 3 subtitles:
    If its have, you can easy import with Subtitle edit
    by File -> Import subtitle from MKV
