  1. Hello Everyone ,
    I am new to DTH Service with recording facilty..i have installed dth service and running good .
    my problem is :
    when i record some videos on DTH Smart Box in USB Device then wants to play that .TS file in laptop using windows media player / VLC Player / Divx Player , it can't play videos..
    Informations from MEDIAINFO software
    Video Codec is Format/Info : Advanced Video Codec
    Video
    Format : AVC
    Format profile : Main@L3
    Format settings, CABAC : Yes
    Format settings, ReFrames : 4 frames
    Width : 704 pixels
    Height : 576 pixels
    Display aspect ratio : 4:3
    Frame rate : 25.000 fps
    Standard : PAL
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Interlaced
    Scan type, store method : Separated fields
    Scan order : Top Field First
    Color range : Limited
    Color primaries : BT.601 PAL
    Transfer characteristics : BT.470 System B, BT.470 System G
    Matrix coefficients : BT.601
    Please Veterans guide me how can i play this type of File
    Thanks in Advance
    Regards
    jenisbob
  2. It's most likely encrypted.
