Hi all
I am bidding on a digital8 camera which can play back hi8 and 8mm tapes.
Using the DV on the camera and into a ADVC100, is this the best way to capture Hi8/8mm tapes.
Or would i be best off buying a hi8 camera with s-video out and going through my Panasonic NV-HS960 (s-video/tbc), through an analogue to hdmi converter and into my capture device at ProRes HQ ?
Thanks for your advice
How are you defining best? Highest quality?
Why would you connect the DV output to the ADVC100 rather than to your computer directly?
https://forum.videohelp.com/threads/376837-DV-conversion-vs-lossless-capture-comparison...uto-load%21%5D
There have been a few other threads recently comparing methods with Video8 source.
Personally I would go for a Hi8 camera with TBC. Whether the internal TBC is better than your other options will depend. The S-VHS VCR will not help you. Its TBC is only operational for internal playback.
Going to all the effort of chaining the equipment together seems pointless to me if you're going to capture to another lossy format (ProRes). -
Thanks Vaporeon for taking the time to respond.
Yes. Best in this context would mean of the two options presented which would be highest quality.How are you defining best?
The digital 8 camera is 4pin firewire. The ADVC 100 has a firewire 4pin input and a 9pin output and my mac has a 9pin. When written out like this.. I see your point. Infact... I will buy a 4 pin to 9pin cable today to cut out the middle tech.Why would you connect the DV output to the ADVC100 rather than to your computer directly?
Its a good point and only one that i would consider if it was suggested that SVideo was the best way to capture.Going to all the effort of chaining the equipment together seems pointless to me if you're going to capture to another lossy format (ProRes).
The reason that i suggested it is because i am putting together a second capture system with the tools that i have. I have a HD capture device called the ninja 2. It captures to ProRes HQ on a 1tb hard drive. It also includes an LCD monitor built into it so i dont need to buy a 2nd computer and monitor. I use it on my HD cameras to capture direct to ProRes rather than AVCHD.
I am getting lots more requestes to convert old tapes for people and before i get swamped, I am looking for affordable ways to capture footage without having to buy lots of equipment (computer/monitor/advc or other)
I would really be interested to hear if you would you suggest an alternate way with less equipment. Thanks again for your input.Last edited by Sir_Loin; 9th Mar 2016 at 17:24.
DV loses a lot of quality, so ProRes (422?) won't be "high quality" anymore.
The data is already gone, thrown away by the DV converter.Want my help? Ask here! (not via PM!)
Best video capture device with higher bit rate for converting Hi8 tapes?
By Studly in forum Capturing and VCRReplies: 10Last Post: 21st Jan 2015, 18:15 -
Can Hi8 distorted tapes recorded on 8mm camcorder, play on Hi8 camcorder?
By RebeccaJB in forum Newbie / General discussionsReplies: 7Last Post: 27th Jul 2014, 17:39 -
How do I use VirtualDub to capture 8mm/camcorder VHS tapes?
By Duder_Me in forum Capturing and VCRReplies: 23Last Post: 27th Jun 2014, 08:30 -
I need to transfer my miniDV and old hi8 tapes tapes to dvd
By bryanport in forum DVD & Blu-ray RecordersReplies: 9Last Post: 21st Dec 2012, 19:53 -
Capture Analog 8mm Video 8 Tapes to DV - What equip will produce best Qual
By koop in forum Capturing and VCRReplies: 7Last Post: 4th Apr 2012, 23:36
