I need some help please!!!!
I have a video headrest that states its resolution is 800x480 16:9
This unit plays avi files as long as they are encoded with divx/xvid and mp3 audio.
I have an avi file that is 720x432 that plays full screen (takes up the whole screen and looks nice)
I have another avi that is 720x480 that plays but it doesnt play in fullscreen mode (letterbox)
So my question is, do I need to convert all of my 720x480's to 720x432 so I can fullscreen?
And if so, what should I use?
All files "play" fine...they just dont play at full screen
Thanks!
You could try change the Pixel AR: with Mpeg4 modifier. Try Pixel AR: Square Pixels or 16:19 and Display AR: 4:3 or 16:9.
If that wont help and your video is not 2:35:1(it should contain black borders) can you crop with Xmedia Recode(use the DVD Player preset and under Filters/Preview add the Crop filter) or use the old Handbrake 0.9.8 (https://www.videohelp.com/software/HandBrake/old-versions#download if you really need AVI Xvid/Divx). You will lose video quality....Last edited by Baldrick; 9th Mar 2016 at 03:52.
HandBrake Anamorphic custom aspect ratio x resolution (Help)
By yro in forum Video ConversionReplies: 1Last Post: 10th May 2014, 07:03 -
MP4 to DVD - Changing the aspect ratio/resolution
By Just Some Guy in forum Video ConversionReplies: 2Last Post: 28th Jul 2013, 07:26 -
Trouble with aspect ratio and resolution with CapDVHS
By ckp in forum Capturing and VCRReplies: 69Last Post: 1st Jul 2011, 13:53 -
Resolution & Aspect Ratio
By markf78 in forum Video ConversionReplies: 4Last Post: 11th Apr 2011, 14:17 -
Resizing: Resolution and Aspect Ratio
By roflwaffle in forum Video ConversionReplies: 7Last Post: 9th Apr 2011, 08:25
