My Computer:
p3 1ghz
192 mb rdram
70 gig hd
Ati Tv wonder pci
what i did to get higher resolutions was download the drivers from soundforge. It works now in high resolutions but i get quite a few problems. The audio sync is a little off but its not huge. The biggest probelm is the frame dropping. It will be ok at the begining but then at some points it will just stop but the audio will keep on going. I lose like 300 frames for 30 mins. I heard u need to defrag ur hd so i did that. Today i capped 1 hour and 15 minutes of video and dropped 1300 frames. I use Picvideo compression and cap at 640 by 480. When i stop the capture it says something about capture rate is to high or something. IF SOMEONE COULD PLEASE ASAP IT WOULD BE REALLY APPRECIATED. THANKS :D
Could you post the link to where you got these drivers? I cannot seem to get vdub to capture higher then 352x240..
TKS
ATI TV Wonder 650 PCI - Black Screen in virtualdub
By HidenSeek in forum Capturing and VCRReplies: 50Last Post: 21st Mar 2012, 09:18 -
Ati 600 usb stick and virtualdub capture
By buckethead in forum Capturing and VCRReplies: 4Last Post: 8th Mar 2011, 16:13 -
Diamond ATI Tv Wonder 750 USB and virtualdub
By buckethead in forum Capturing and VCRReplies: 9Last Post: 31st Jul 2010, 03:34 -
Big Problem
By k_pratl54 in forum DVD RippingReplies: 7Last Post: 9th Mar 2010, 20:37 -
problem with divx with newer virtualdub and virtualdub mod
By goingape in forum Newbie / General discussionsReplies: 9Last Post: 26th Mar 2008, 17:08
