My goal is to combine ten "4GB" TV DVDs into one BD50, with basic menu. The menu only needs text allowing an episode to be selected.
MultiAVCHD is hanging, so please suggest alternative solutions if that will be easier than trying to make it work.
My compilation is 28 episodes. MultiAVCHD processes the first 23 episodes without issue, but then hangs on the 24th file. The step is shown as "Extracting DVD audio..." with a stuck progress bar.
The status window shows:[12:47:36] Processing (DVD (04) T:\[path]\VIDEO_TS\)...mplayer.exe shows 25% CPU usage on my 4-core.
[12:47:36] Pre-processing DVD input (T:\[path]\VIDEO_TS\)...
[12:47:37] *** Detected duration: 00:22:56
[12:47:37] !!! No subtitles found!
[12:47:37] *** Extracting audio (mplayer)...
[12:47:37] *** Extracting ac3 track #128 (eng)...
Troubleshooting:
Clearly, mplayer doesn't like something about this particular file. I don't know where to go from here, though.
- All episodes = hang
- First 23 eps only = success
- 24th ep alone = hang
Results 1 to 11 of 11
One way to do this is with BD Rebuilder. Set it to Quick-Play Backup under Mode. Set Output to 50gb size.
You'll have to have all of the DVD's decrypted and ripped to the hard drive in one folder. So this is what it should look like...a top folder, lets call it the name of your tv series, and a few folders within that top folder. Each of those folders would be an individual DVD with the episodes....Disc 1, Disc 2, and so forth.
Now click on File-->Import-->DVDs Quick Reauthored and select your top folder as input. This will bring up a list of titles (episodes) that the program can find. You may want to rename them at this point if you know the episode names. Hit Save and Continue. It will take some time before BD Rebuilder finishes examining the files and preparing them for Blu-ray format, but once it does finish with preparations, you will need to click on Backup to build the Blu-ray.
I've never done this with more than 15 episodes, so I'm not certain that it will work with 28. You'd just have to try it.Last edited by Kerry56; 7th Mar 2016 at 21:59.
This is good stuff. Helped me as well. thanks so much for posting as well as the in-depth instructions.
I don't wan to hijack the thread but I have a related quick question: I have Blu-ray discs I purchased where 1 part is on one disc and part 2 is one a second disc. I'd like to have them both on the same disc in continual play. Will this also work with 2-part DVDs/Blu-rays? -
Yes. The same instructions apply, you just have to go to File-->Import-->BD's Quick Reauthored instead. Depending on the size of the movies, the program might have to re-encode them to fit. And of course, you lose original menus and extras.
Quick Play mode may not be necessary, its just the way I've done it in the past. The mode may be disabled when using the Import function for multiple DVD's and Blu-ray, but I don't know this for certain. Would have to look it up over at doom9.
Edit: Oops, I notice that you said continual play. You won't get continual play this way. You'll have two titles, which you can select from the very basic menu that is created. To have continual play you'd need to extract the m2ts files and combine them before authoring back to Blu-ray format. You can join them with the Append function in AviDemux if you get lucky. It is a bit buggy. Output as an MKV file using the MKV muxer, then import this into tsMuxeR and create a new Blu-ray without a menu.Last edited by Kerry56; 8th Mar 2016 at 23:56.
Yeah, i've also had some not so fortunate luck with AviDemux. I'm actually on a Mac and usually run the suggested programs via Windows 10/Bootcamp. I need to see if there is a substitute for AviDemux. I don't want the quality to suffer and hope to put it all on a blu-ray DL
You really know your stuff. Thanks, man. I'll try this tonight. And not to look 'a gift horse in the mouth' but is there no way to have a basic menu as well? The goal is to combine the 2 Blu-ray Discs into 1 disc with continual play but allowing for it scene selections at maybe 15 or 20 min intervals.
I'd combine the the m2ts files then use MultiAVCHD to make your menu with chapter points. Yes its the program at the start of this thread. It is known to be buggy, and takes a great deal of patience, but is the only reasonably good Blu ray authoring program that is free to use.
Thanks for the instructions, and sorry for not responding earlier.
BD Rebuilder also gave me an error message, which led me to more troubleshooting. After I tried to open the disc with MakeMKV, it became clear that all of the issues are due to some sort of problem with the original DVD; I believe an authoring error rather than an actual video or audio error.
It's a fan-made DVD, so I've contacted the guy who made them for himself and shared them with me. I own the actual retail release, but it was edited from the original broadcasts, so this is to fill in the gaps. -
You can alter the Import settings in BD Rebuilder so as to have the titles play consecutively rather than returning to the basic menu when a title is finished (i.e. the equivalent of a "Play All" button) so you would get continuous play if that option is selected.
Putting multiple DVD images onto single Blu-Ray disc?
By Super Warrior in forum Authoring (Blu-ray)Replies: 9Last Post: 12th Oct 2014, 16:59 -
How to re-author a Blu-ray disc that's not working right now.
By Big-Louis-1971 in forum Authoring (Blu-ray)Replies: 1Last Post: 10th Aug 2013, 05:25 -
multiAVCHD Blu Ray content on DVD-R problems in Blu Ray player
By erek in forum Authoring (Blu-ray)Replies: 9Last Post: 6th Aug 2013, 22:25 -
Multiple DVDs on a Blu-Ray Disc
By rstrom2008 in forum Newbie / General discussionsReplies: 1Last Post: 10th Jan 2012, 06:34 -
How do I author multiple x264 videos to blu ray without reencoding?
By Onceler2 in forum Authoring (Blu-ray)Replies: 12Last Post: 14th Sep 2011, 16:49
