Hello,
I'm trying to find a way that I could record an outdoor event (a kids' baseball game) using an external camera, connected in some way to a smartphone, then use the smartphone's 4G internet to live-stream the footage to a couple of dozen viewers overseas. I won't have an external power source, so this would need to use battery power (including an external battery pack). Would need to run for a couple of hours.
I have done this in the past using just a smartphone and ustream, but the camera isn't great, and I am hoping to use a better camera (wider angle lens etc). Just not sure what hardware/software combination would work. My budget is only $200 or so. Not looking for anything like broadcast quality of course.
Any ideas gratefully received !
Chris
	I don't think it will be that simple. With an android smartphone can you connect an external camera with usb, see https://play.google.com/store/apps/details?id=infinitegra.trial.usbcamera
 But then must it support restreaming with ustream for example.
	Thanks both. I also found http://camerafi.com/app/camerafi-live/ which I will look into.
 Chris
  Low-budget camera for web videos?By tried42long in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 18th Sep 2014, 23:01
  SDI to web stream?By bradb in forum Newbie / General discussionsReplies: 1Last Post: 3rd Dec 2013, 19:38
  using CMOS web camera for 8mm film transferBy mammo1789 in forum Capturing and VCRReplies: 0Last Post: 31st Aug 2012, 22:19
  Streaming video camera to webBy jackos in forum Video Streaming DownloadingReplies: 5Last Post: 20th Apr 2012, 19:49
  Capture audio from web stream ?By Zetti in forum Capturing and VCRReplies: 2Last Post: 12th Dec 2011, 18:20
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
