Hello
I am using a PC running Win 10.
I got a movie which is in the MKV format. The audio is in TrueHD format.
If I play the movie in Windows Media Player or Films & TV app there video is OK but the audio doesn't work. If I play the movie in VLC the audio is fine but the video is not full screen but just a square in the centre and changing the settings simply distorts the picture.
So what should I do and how should I do it to make sure that I can watch both full screen video and hear the audio.
Thanks for any help!!
J
You can try install the Lav filters and see if you get the audio working with WMP.
Have you tried all settings under Video->Zoom and Video->Aspect ratio in VLC Media player?
Or try another player like MPC-HC or PotPlayer or Smplayer. -
Hello Baldrick
I wanted to avoid trying lots of different players, but that is a solution and I tried Potplayer and it seems to work OK.
I didn't know what to do with Lavfilters and in reply to your other question: yes, I tried all the zoom and aspect ratio settings in VLC and nothing worked; the picture was always distorted.
Thanks for your help all the same.
J -
You should just install lavfilters...and then it might work with Windows Media Player as it should use lavfilter to decode the audio.
Convert video to size
By ashkan_vpm2 in forum Video ConversionReplies: 10Last Post: 5th Mar 2016, 18:50 -
convert video into same size selecting particular audio track
By ani001 in forum Newbie / General discussionsReplies: 3Last Post: 11th Nov 2015, 20:13 -
VLC media library. Can I adjust the text size?
By HitTheRoad in forum Video Streaming DownloadingReplies: 0Last Post: 15th Mar 2015, 04:37 -
adjust/correct speed of video and audio?
By Touch_A_Mountain in forum RestorationReplies: 12Last Post: 5th Dec 2013, 21:51 -
How to add audio(.mp3) & adjust in video(.mkv) & burn in vbo ?
By ashe09 in forum AudioReplies: 0Last Post: 16th Jul 2011, 04:06
