I use avidemux to hardcode subtitles or add a black border for subtitles. I know its not stable but recently it has started freezing (not crashing) more or less every time. Its not the type of file. It freezes with .ts and .mkv even mkvs I have put through mkvmerge to create a new header. I am using windows 10. I have updated all drivers. I have upgraded without success to Avidemux 2.6.12. I have deleted the folder in Appdata. All I get is "not responding". I attach the latest log in the hope of that someone can point me in the direction of what is happening. Handbrake works without a problem.
Have you tried an older version of avidemux? Like 2.6.8 https://www.videohelp.com/software/AviDemux/old-versions#download . Latest versuin is not always best.
Or try disable OpenGL under Edit->Preferences, Display and change Video display: SDL and SDL driver: software.
I downloaded an older version but with file in my first post it comes up with a warning about h.264 using "B" frames as a reference which can lead to a crash or stuttering. Perhaps this was the problem although that still does not explain why I have the problem with ts files.
However using a newer version of avidemux with Baldrick's suggestion I had no problems whatsoever. Hopefully that's the answer so thanks Baldrick.
Avidemux crashes with many, many MP4 files. How to handle?
By Diana (Cda) in forum Video ConversionReplies: 6Last Post: 5th Feb 2017, 19:55 -
Avidemux crashes when I open videos with subtitles muxed in them
By TheRandomOne in forum Video ConversionReplies: 4Last Post: 5th Jan 2016, 15:03 -
avidemux
By slaughtersr in forum Newbie / General discussionsReplies: 3Last Post: 3rd Nov 2014, 13:35 -
Avidemux aspect ratio question [from newbie to Avidemux]
By ANOther1676 in forum EditingReplies: 1Last Post: 20th Jan 2012, 20:07 -
How do i do this with avidemux?
By Jmart285 in forum Video ConversionReplies: 3Last Post: 27th Apr 2011, 01:13
