Does anybody know what the track IDs tsmuxer uses are?
I have seen:
used in batch files. What do 4113 and 4352 refer to? Is there a guide for this?fps=, insertSEI, contSPS, track=4113 and A_LPCM, %audioFile%, track=4352
'Do I look absolutely divine and regal, and yet at the same time very pretty and rather accessible?' - Queenie
4113 and 4352 are IDs of the streams inside the ts container.
MediaInfo and other tools let you see the ids of each track, for example:
Code:General ID : 1 (0x1) Complete name : h:\00000.split.1.m2ts Format : BDAV Format/Info : Blu-ray Video File size : 185 MiB Duration : 58s 308ms Overall bit rate mode : Variable Overall bit rate : 26.6 Mbps Maximum Overall bit rate : 35.5 Mbps Video ID : 4113 (0x1011) Menu ID : 1 (0x1) Format : VC-1 Format profile : Advanced@L3 Codec ID : 234 Duration : 57s 975ms Bit rate : 21.9 Mbps Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate : 23.976 (24000/1001) fps Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Compression mode : Lossy Bits/(Pixel*Frame) : 0.441 Stream size : 151 MiB (82%) Audio #1 ID : 4352 (0x1100) Menu ID : 1 (0x1) Format : AC-3 Format/Info : Audio Coding 3 Mode extension : CM (complete main) Format settings, Endianness : Big Codec ID : 129 Duration : 58s 272ms Bit rate mode : Constant Bit rate : 640 Kbps Channel(s) : 6 channels Channel positions : Front: L C R, Side: L R, LFE Sampling rate : 48.0 KHz Frame rate : 31.250 fps (1536 spf) Compression mode : Lossy Delay relative to video : -49ms Stream size : 4.45 MiB (2%) Language : English Audio #2 ID : 4353 (0x1101) Menu ID : 1 (0x1) Format : TrueHD / AC-3 Mode extension : CM (complete main) Format settings, Endianness : Big Muxing mode : Stream extension Codec ID : 131 Duration : 58s 240ms Bit rate mode : Variable / Constant Bit rate : 640 Kbps Maximum bit rate : 3 345 Kbps Channel(s) : 6 channels Channel positions : Front: L C R, Side: L R, LFE Sampling rate : 48.0 KHz Frame rate : 31.250 fps (1536 spf) Delay relative to video : -49ms Stream size : 4.44 MiB (2%) Language : English Audio #3 ID : 4354 (0x1102) Menu ID : 1 (0x1) Format : AC-3 Format/Info : Audio Coding 3 Mode extension : CM (complete main) Format settings, Endianness : Big Codec ID : 129 Duration : 58s 272ms Bit rate mode : Constant Bit rate : 640 Kbps Channel(s) : 6 channels Channel positions : Front: L C R, Side: L R, LFE Sampling rate : 48.0 KHz Frame rate : 31.250 fps (1536 spf) Compression mode : Lossy Delay relative to video : -49ms Stream size : 4.45 MiB (2%) Language : German Audio #4 ID : 4355 (0x1103) Menu ID : 1 (0x1) Format : AC-3 Format/Info : Audio Coding 3 Mode extension : CM (complete main) Format settings, Endianness : Big Codec ID : 129 Duration : 58s 272ms Bit rate mode : Constant Bit rate : 640 Kbps Channel(s) : 6 channels Channel positions : Front: L C R, Side: L R, LFE Sampling rate : 48.0 KHz Frame rate : 31.250 fps (1536 spf) Compression mode : Lossy Delay relative to video : -49ms Stream size : 4.45 MiB (2%) Language : Spanish Audio #5 ID : 4356 (0x1104) Menu ID : 1 (0x1) Format : AC-3 Format/Info : Audio Coding 3 Format profile : Dolby Digital Mode extension : CM (complete main) Format settings, Endianness : Big Codec ID : 129 Duration : 58s 272ms Bit rate mode : Constant Bit rate : 192 Kbps Channel(s) : 2 channels Channel positions : Front: L R Sampling rate : 48.0 KHz Frame rate : 31.250 fps (1536 spf) Compression mode : Lossy Delay relative to video : -49ms Stream size : 1.33 MiB (1%) Language : English Audio #6 ID : 4357 (0x1105) Menu ID : 1 (0x1) Format : AC-3 Format/Info : Audio Coding 3 Format profile : Dolby Digital Mode extension : CM (complete main) Format settings, Endianness : Big Codec ID : 129 Duration : 58s 272ms Bit rate mode : Constant Bit rate : 192 Kbps Channel(s) : 2 channels Channel positions : Front: L R Sampling rate : 48.0 KHz Frame rate : 31.250 fps (1536 spf) Compression mode : Lossy Delay relative to video : -49ms Stream size : 1.33 MiB (1%) Language : English Audio #7 ID : 4358 (0x1106) Menu ID : 1 (0x1) Format : AC-3 Format/Info : Audio Coding 3 Format profile : Dolby Digital Mode extension : CM (complete main) Format settings, Endianness : Big Codec ID : 129 Duration : 58s 272ms Bit rate mode : Constant Bit rate : 192 Kbps Channel(s) : 2 channels Channel positions : Front: L R Sampling rate : 48.0 KHz Frame rate : 31.250 fps (1536 spf) Compression mode : Lossy Delay relative to video : -49ms Stream size : 1.33 MiB (1%) Language : English Audio #8 ID : 4359 (0x1107) Menu ID : 1 (0x1) Format : AC-3 Format/Info : Audio Coding 3 Format profile : Dolby Digital Mode extension : CM (complete main) Format settings, Endianness : Big Codec ID : 129 Duration : 58s 272ms Bit rate mode : Constant Bit rate : 192 Kbps Channel(s) : 2 channels Channel positions : Front: L R Sampling rate : 48.0 KHz Frame rate : 31.250 fps (1536 spf) Compression mode : Lossy Delay relative to video : -49ms Stream size : 1.33 MiB (1%) Language : English Audio #9 ID : 6656 (0x1A00) Menu ID : 1 (0x1) Format : E-AC-3 Format/Info : Audio Coding 3 Format settings, Endianness : Big Codec ID : 161 Duration : 58s 272ms Bit rate mode : Constant Bit rate : 192 Kbps Channel(s) : 2 channels Channel positions : Front: L R Sampling rate : 48.0 KHz Frame rate : 187.500 fps (256 spf) Compression mode : Lossy Delay relative to video : -49ms Stream size : 1.33 MiB (1%) Language : English Text #1 ID : 4608 (0x1200) Menu ID : 1 (0x1) Format : PGS Codec ID : 144 Language : English Text #2 ID : 4609 (0x1201) Menu ID : 1 (0x1) Format : PGS Codec ID : 144 Language : German Text #3 ID : 4610 (0x1202) Menu ID : 1 (0x1) Format : PGS Codec ID : 144 Language : Spanish Text #4 ID : 4611 (0x1203) Menu ID : 1 (0x1) Format : PGS Codec ID : 144 Language : Chinese Text #5 ID : 4612 (0x1204) Menu ID : 1 (0x1) Format : PGS Codec ID : 144 Language : Korean Text #6 ID : 4613 (0x1205) Menu ID : 1 (0x1) Format : PGS Codec ID : 144 Language : Danish Text #7 ID : 4614 (0x1206) Menu ID : 1 (0x1) Format : PGS Codec ID : 144 Language : Finnish Text #8 ID : 4615 (0x1207) Menu ID : 1 (0x1) Format : PGS Codec ID : 144 Language : Norwegian Text #9 ID : 4616 (0x1208) Menu ID : 1 (0x1) Format : PGS Codec ID : 144 Language : Portuguese Text #10 ID : 4617 (0x1209) Menu ID : 1 (0x1) Format : PGS Codec ID : 144 Language : Swedish Text #11 ID : 4618 (0x120A) Menu ID : 1 (0x1) Format : PGS Codec ID : 144 Delay relative to video : 376ms Language : Chinese Text #12 ID : 4619 (0x120B) Menu ID : 1 (0x1) Format : PGS Codec ID : 144 Delay relative to video : 334ms Language : Korean Text #13 ID : 4620 (0x120C) Menu ID : 1 (0x1) Format : PGS Codec ID : 144 Delay relative to video : 14s 56ms Language : Chinese Text #14 ID : 4621 (0x120D) Menu ID : 1 (0x1) Format : PGS Codec ID : 144 Delay relative to video : 14s 56ms Language : Korean Text #15 ID : 4622 (0x120E) Menu ID : 1 (0x1) Format : PGS Codec ID : 144 Duration : 55s 285ms Delay relative to video : 1s 168ms Language : Chinese Text #16 ID : 4623 (0x120F) Menu ID : 1 (0x1) Format : PGS Codec ID : 144 Duration : 55s 284ms Delay relative to video : 1s 168ms Language : Korean Text #17 ID : 4624 (0x1210) Menu ID : 1 (0x1) Format : PGS Codec ID : 144 Language : Chinese Text #18 ID : 4625 (0x1211) Menu ID : 1 (0x1) Format : PGS Codec ID : 144 Language : Korean Text #19 ID : 4626 (0x1212) Menu ID : 1 (0x1) Format : PGS Codec ID : 144 Duration : 57s 204ms Delay relative to video : 1s 1ms Language : English Text #20 ID : 4627 (0x1213) Menu ID : 1 (0x1) Format : PGS Codec ID : 144 Duration : 57s 204ms Delay relative to video : 1s 1ms Language : German Text #21 ID : 4628 (0x1214) Menu ID : 1 (0x1) Format : PGS Codec ID : 144 Duration : 57s 202ms Delay relative to video : 1s 1ms Language : Spanish Text #22 ID : 4629 (0x1215) Menu ID : 1 (0x1) Format : PGS Codec ID : 144 Duration : 57s 202ms Delay relative to video : 1s 1ms Language : Chinese Text #23 ID : 4630 (0x1216) Menu ID : 1 (0x1) Format : PGS Codec ID : 144 Duration : 57s 202ms Delay relative to video : 1s 1ms Language : Korean Text #24 ID : 4631 (0x1217) Menu ID : 1 (0x1) Format : PGS Codec ID : 144 Duration : 57s 204ms Delay relative to video : 1s 1ms Language : Danish Text #25 ID : 4632 (0x1218) Menu ID : 1 (0x1) Format : PGS Codec ID : 144 Duration : 57s 97ms Delay relative to video : 1s 1ms Language : Finnish Text #26 ID : 4633 (0x1219) Menu ID : 1 (0x1) Format : PGS Codec ID : 144 Duration : 57s 202ms Delay relative to video : 1s 1ms Language : Norwegian Text #27 ID : 4634 (0x121A) Menu ID : 1 (0x1) Format : PGS Codec ID : 144 Duration : 57s 202ms Delay relative to video : 1s 1ms Language : Portuguese Text #28 ID : 4635 (0x121B) Menu ID : 1 (0x1) Format : PGS Codec ID : 144 Duration : 57s 205ms Delay relative to video : 1s 1ms Language : Swedish Text #29 ID : 4636 (0x121C) Menu ID : 1 (0x1) Format : PGS Codec ID : 144 Duration : 57s 204ms Delay relative to video : 1s 1ms Language : German Text #30 ID : 4637 (0x121D) Menu ID : 1 (0x1) Format : PGS Codec ID : 144 Duration : 57s 202ms Delay relative to video : 1s 1ms Language : Spanish
users currently on my ignore list: deadrats, Stears555, marcorocchini -
thanks!
How do I (BATCH) set a specific subtitle track, and audio track as default?
By MountainSplash00 in forum Newbie / General discussionsReplies: 3Last Post: 2nd Dec 2014, 06:53 -
TSMuxer crashing error code -3 TSMuxer GUI
By petermg in forum Authoring (Blu-ray)Replies: 2Last Post: 30th Nov 2012, 15:21 -
Sony Vegas Automated track volume based off separate track?
By Mitalis in forum EditingReplies: 5Last Post: 18th Nov 2012, 17:51 -
Setting default audio track with TsmuxeR
By bruce73 in forum Newbie / General discussionsReplies: 5Last Post: 30th Jul 2012, 07:24 -
Extracting DTS-HD track with tsmuxer
By rantonio in forum Blu-ray RippingReplies: 3Last Post: 18th Mar 2011, 08:23
