Hi folks,
Just wondering if anyone has used or knows where to get a PAL VHS test pattern tape, to test old VCRs.
Cheers.
If you want to check VCRs against spec, you will need a professional alignment tape. Good luck — they are nearly extinct. Perhaps you can borrow/rent one from a nearby tech who does vintage repairs. Otherwise, you'll have to make your own on a machine that you trust. It will give you an idea of a subject VCR's performance compared to the trusted deck.
VHS tape audio/video keep dropping out during playback
By Special K in forum Newbie / General discussionsReplies: 5Last Post: 15th Jan 2014, 12:09 -
PAL LP VHS Tape - "Missing" colors during capture
By FrankDrebin in forum Capturing and VCRReplies: 6Last Post: 15th Aug 2013, 12:26 -
Test of various VCRs Image Quality from VHS Tape (Big Pics)
By BrainStorm69 in forum RestorationReplies: 47Last Post: 2nd Aug 2013, 16:58 -
recording test pattern on a vcr from PC
By mammo1789 in forum Capturing and VCRReplies: 11Last Post: 13th Apr 2012, 10:59 -
converting bad laser Sony DVD players into Test Pattern Signal Generators?
By turnkit in forum DVD & Blu-ray PlayersReplies: 5Last Post: 10th Jan 2012, 03:46
