I was recording a camshow from Chaturbate, and for the first time ever, the file size came up really small, but it was recording for over an hour. 104 minutes, but the file is 31KB. I used RTMPDumpHelper and rtmpsuck. Using FFMPEG didn't work, just converted it to 22.5MB, the file itself can't be seeked, doesn't even play. The slider moves, showing it's playing, but the image is frozen.
Well normally they're in appropriate sizes, except this particular one. The stream went offline for a second, maybe that had something to do with it, but it happened before and things turned out fine. VPN maybe? It recorded just fine previously.
F4F File Video Duration
By Tom Saurus in forum Video Streaming DownloadingReplies: 0Last Post: 20th Feb 2016, 10:41 -
Split video by duration while encoding?
By Shaorin in forum Newbie / General discussionsReplies: 4Last Post: 19th Jan 2014, 04:27 -
how can i calculate frame rate video in ulead video studio speed/duration ?
By fps in forum Video ConversionReplies: 10Last Post: 27th Nov 2013, 16:58 -
MKVmerge extends total time if subtitle duration exceeds video duration
By ankutsa in forum SubtitleReplies: 1Last Post: 7th Sep 2013, 12:08 -
encoded video duration different than vob duration
By fatcharlie in forum Video ConversionReplies: 9Last Post: 4th Dec 2011, 11:04
