Hi
My current work process to capture analog footage is VHS/camera --> ADVC100 --> to iMac I often find that my tapes dropout and therefore create multiple files. Would a TBC prevent this from happening and allow me to capture a single file?
				Results 1 to 11 of 11
	You don't mention what software you are using for capture. Many have the option to save as a single file. In any case DV files can be easily joined losslessly after the fact with almost any DV-compatible editing software.
	Sorry. I should have said.
 I have premiere cc 15 and FCPX and whilst they are able to select "entire tape", they simply don't work for analog and I have to babysit the computer. iMovie is what i have been using latetly as it does not require me to save a new filename with each dropout. Id prefer not to use iMovie as it captures progressive, but i dont really have a choice.
	Thanks vaporeon. I think you are right. I have just done a quick test, and it appears you are correct. Thanks a lot
 I still would like to capture in one go though. Could it be a problem with my ADVC 100?
	I thought this meant that iMovie solves your capture problem as long as it keeps the file interlaced:
 You might try an open source program called Vidi, but I have no idea whether it will split the files. I've never used it.
	It sounds like you have a fairly recent Mac. Do NOT use FCPX or imovie to capture your dv footage. It will automatically be converted to ProRes. DV should remain unmolested DV. Premiere is your best option. I believe there is an option to ignore timecode breaks during capture, but it has been a very long time since I used premiere to capture DV.
	Thanks a lot vaporeon. I will certainly try that out on my next ingest.
 smrpix, all of my imovie captures, are using the DV PAL codec. Just out of interest though, why do you suggest that ProRes is inferior to DV? I ask because i am currently looking at other workflow options and one which I am almost ready to settle with is using a capture device that captures to ProRes HQ.
 I have tried all the settings in premiere to try and make it ignore the dropouts, but I have not had success.
  A single .m4v file to a single DVD-Video disk?By Hamstor in forum Authoring (DVD)Replies: 7Last Post: 25th Sep 2015, 15:37
  what capture software to use for Dazzle Analog to PC ?By mk1059 in forum Capturing and VCRReplies: 5Last Post: 28th Feb 2015, 11:20
  Capture Device For A Single Cpu ComputerBy Jimbo45 in forum Capturing and VCRReplies: 0Last Post: 6th Feb 2014, 13:16
  Multiple Simultaneous Capture on a Single ComputerBy Satisfied_Camel in forum Capturing and VCRReplies: 4Last Post: 21st Jun 2012, 19:29
  mni dv footage captureBy zoranb in forum Capturing and VCRReplies: 28Last Post: 5th May 2012, 18:51
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
