Our website is made possible by displaying online advertisements to our visitors. Consider supporting us by disable your adblocker or Try ConvertXtoDVD and convert all your movies to DVD. Free trial ! :)
  1. Member vhelp's Avatar
    Mar 2001
    New York
    solved, see post # 3
    Hi, I have a dell inspiron windows 7 64bit home premium laptop and I want to finally change the keyboard layout to the usual one we all use.
    When I want to enter a quotation mark " or the ` and ' chars, I have to hit those keys twice. If I hit them once, the char does not appear, and if i hit a second key, any key, then its (for lack of correct term) referenced key code shows up instead.
    here are some examples for the " char, if I hit that key, followed by another key:
    "j "c "7 and so on.
    here are some examples for the ' char, if I hit that key, followed by another key:
    and so on.
    Oct 2005
    666th portal
    control panel/region and languages/keyboards and languages is where i would look
  3. Member vhelp's Avatar
    Mar 2001
    New York
    Solved..
    That was it, aedipuss..
    in Control panel:
    1. click on "Click, Languages, and Region"
    2. Region and Language
       (Change the date, time, or number format)
    3. select the [Keyboards and Languages] tab
    4. click the [Change keyboards...] button
    5. and finally, in the drop-down, change from
    [English (United States) - United States-International]
       to
    [English (United States) - US]
    6. select [Apply] and [OK] buttons
    7. click [OK] button.
    8. finished
    Five years of having to deal with this.. no more, Pfew! Thank you!
    EDIT: while it did work in notepad.exe, it would not work in other apps. But through trail and error, I had to install the "English (Canada)" layout (below) and then select that as the primary. Then it worked in anything-everything.
