  1. Hello guys,
    Today my backup camera was a Praktica DVC 11.4 it produces an AVI container file with h264 codec. Problem with this one is, not even VLC can play this file, ironically BSPlayer can (no timestamp so I dont know for how long and only video no audio), of course importing to Adobe premiere, Yamb or handbrake is impossible.
    I tried to demux the AVI with ffmpeg using:
    ffmpeg -i input.avi
    <-- to get stream info
    but I got this:
    C:\Users\DaemonCave\Desktop\Nova mapa (3)\Video\RAW\Golum\ffmpeg-20160301-git-1c7e2cf-win64-static\bin>ffmpeg -i input.avi
    ffmpeg version N-78843-g1c7e2cf Copyright (c) 2000-2016 the FFmpeg developers
      built with gcc 5.3.0 (GCC)
      configuration: --enable-gpl --enable-version3 --disable-w32threads --enable-avisynth --enable-bzlib --enable-fontconfig --enable-frei0r --enable-gnutls --enable-iconv --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libdcadec --enable-libfreetype --enable-libgme --enable-libgsm --enable-libilbc --enable-libmodplug --enable-libmfx --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenjpeg --enable-libopus --enable-librtmp --enable-libschroedinger --enable-libsoxr --enable-libspeex --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvo-amrwbenc --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxavs --enable-libxvid --enable-libzimg --enable-lzma --enable-decklink --enable-zlib
      libavutil      55. 19.100 / 55. 19.100
      libavcodec     57. 27.101 / 57. 27.101
      libavformat    57. 27.100 / 57. 27.100
      libavdevice    57.  0.101 / 57.  0.101
      libavfilter     6. 37.100 /  6. 37.100
      libswscale      4.  0.100 /  4.  0.100
      libswresample   2.  0.101 /  2.  0.101
      libpostproc    54.  0.100 / 54.  0.100
    [h264 @ 0000025c4633a260] Stream #0: not enough frames to estimate rate; consider increasing probesize
    Input #0, h264, from 'input.avi':
      Duration: N/A, bitrate: N/A
        Stream #0:0: Video: h264 (Main), yuv420p, 1920x1080 [SAR 1:1 DAR 16:9], 29.97 fps, 29.97 tbr, 1200k tbn, 59.94 tbc
    At least one output file must be specified
    Decided to try with the following in a bat file:
    @ECHO OFF
    for %%a in (*.avi) do ffmpeg -i "%%a" -vcodec copy -acodec copy -f mp4 -y "%%~na".mp4
    but I got this:
    C:\Users\DaemonCave\Desktop\Nova mapa (3)\Video\RAW\Golum\ffmpeg-20160301-git-1c7e2cf-win64-static\bin>convert.bat
    [h264 @ 000001cbe021a600] Stream #0: not enough frames to estimate rate; consider increasing probesize
    Input #0, h264, from 'input.AVI':
    Output #0, mp4, to 'input.mp4':
      Metadata:
        encoder         : Lavf57.27.100
        Stream #0:0: Video: h264 ([33][0][0][0] / 0x0021), yuv420p, 1920x1080 [SAR 1:1 DAR 16:9], q=2-31, 29.97 fps, 29.97 tbr, 1200k tbn, 1200k tbc
    Stream mapping:
      Stream #0:0 -> #0:0 (copy)
    Press [q] to stop, [?] for help
    [mp4 @ 000001cbe0a9a020] Timestamps are unset in a packet for stream 0. This is deprecated and will stop working in the future. Fix your code to set the timestamps properly
    [mp4 @ 000001cbe0a9a020] pts has no value
        Last message repeated 133 times
    [NULL @ 000001cbe022c020] SEI type 192 size 1312 truncated at 496
        Last message repeated 194 times
    [mp4 @ 000001cbe0a9a020] pts has no valueB time=00:00:10.91 bitrate=15341.8kbits/s speed=21.8x
        Last message repeated 371 times
    [mp4 @ 000001cbe0a9a020] pts has no valueB time=00:00:23.33 bitrate=12130.2kbits/s speed=23.3x
        Last message repeated 100 times
    [NULL @ 000001cbe022c020] sps_id 1 out of range
        Last message repeated 276 times
    [mp4 @ 000001cbe0a9a020] pts has no valueB time=00:00:35.94 bitrate=9963.2kbits/s speed=23.9x
    [NULL @ 000001cbe022c020] missing picture in access unit with size 397
        Last message repeated 143 times
    [NULL @ 000001cbe022c020] sps_id 32 out of range
        Last message repeated 123 times
    [mp4 @ 000001cbe0a9a020] pts has no valueB time=00:00:48.25 bitrate=8750.5kbits/s speed=24.1x
        Last message repeated 264 times
    [mp4 @ 000001cbe0a9a020] pts has no valueB time=00:00:57.09 bitrate=8061.5kbits/s speed=22.8x
        Last message repeated 263 times
    [mp4 @ 000001cbe0a9a020] pts has no valueB time=00:01:05.90 bitrate=7583.5kbits/s speed=21.9x
        Last message repeated 250 times
    [mp4 @ 000001cbe0a9a020] pts has no valueB time=00:01:14.28 bitrate=7184.1kbits/s speed=21.2x
        Last message repeated 99 times
    [mp4 @ 000001cbe0a9a020] pts has no valueB time=00:01:17.61 bitrate=7045.8kbits/s speed=19.4x
        Last message repeated 221 times
    [mp4 @ 000001cbe0a9a020] pts has no valueB time=00:01:25.02 bitrate=6767.2kbits/s speed=18.9x
        Last message repeated 260 times
    [mp4 @ 000001cbe0a9a020] pts has no valueB time=00:01:33.73 bitrate=6515.9kbits/s speed=18.7x
        Last message repeated 256 times
    [mp4 @ 000001cbe0a9a020] pts has no valueB time=00:01:42.30 bitrate=6321.6kbits/s speed=18.6x
    [mp4 @ 000001cbe0a9a020] pts has no valueB time=00:01:51.15 bitrate=6147.6kbits/s speed=18.5x
        Last message repeated 326 times
    [mp4 @ 000001cbe0a9a020] pts has no valueB time=00:02:02.06 bitrate=5950.2kbits/s speed=18.7x
    [mp4 @ 000001cbe0a9a020] pts has no valueB time=00:02:10.87 bitrate=5827.0kbits/s speed=18.7x
        Last message repeated 258 times
    [mp4 @ 000001cbe0a9a020] pts has no valueB time=00:02:19.51 bitrate=5710.8kbits/s speed=18.6x
        Last message repeated 265 times
    [mp4 @ 000001cbe0a9a020] pts has no valueB time=00:02:28.38 bitrate=5617.1kbits/s speed=18.5x
        Last message repeated 262 times
    [mp4 @ 000001cbe0a9a020] pts has no valueB time=00:02:37.16 bitrate=5527.1kbits/s speed=18.5x
    [mp4 @ 000001cbe0a9a020] pts has no valueB time=00:02:46.04 bitrate=5442.3kbits/s speed=18.4x
    [mp4 @ 000001cbe0a9a020] pts has no valueB time=00:02:54.61 bitrate=5376.2kbits/s speed=18.3x
    [mp4 @ 000001cbe0a9a020] pts has no valueB time=00:03:03.39 bitrate=5313.3kbits/s speed=18.3x
        Last message repeated 254 times
    [mp4 @ 000001cbe0a9a020] pts has no valueB time=00:03:11.90 bitrate=5255.7kbits/s speed=18.2x
        Last message repeated 166 times
    [NULL @ 000001cbe022c020] sps_id 8 out of range
        Last message repeated 94 times
    [mp4 @ 000001cbe0a9a020] pts has no valueB time=00:03:20.64 bitrate=5202.4kbits/s speed=18.2x
        Last message repeated 318 times
    [mp4 @ 000001cbe0a9a020] pts has no valueB time=00:03:31.28 bitrate=5153.5kbits/s speed=18.3x
        Last message repeated 209 times
    [NULL @ 000001cbe022c020] sps_id 2 out of range
        Last message repeated 40 times
    [mp4 @ 000001cbe0a9a020] pts has no valueB time=00:03:39.66 bitrate=5106.6kbits/s speed=18.3x
        Last message repeated 307 times
    [mp4 @ 000001cbe0a9a020] pts has no valueB time=00:03:49.93 bitrate=5064.2kbits/s speed=18.4x
        Last message repeated 269 times
    [mp4 @ 000001cbe0a9a020] pts has no valueB time=00:03:58.94 bitrate=5029.4kbits/s speed=18.3x
        Last message repeated 304 times
    [mp4 @ 000001cbe0a9a020] pts has no valueB time=00:04:09.12 bitrate=4985.7kbits/s speed=18.4x
    [mp4 @ 000001cbe0a9a020] pts has no valueB time=00:04:17.93 bitrate=4953.2kbits/s speed=18.4x
        Last message repeated 305 times
        Last message repeated 17 times
    [mp4 @ 000001cbe0a9a020] pts has no valueB time=00:04:28.74 bitrate=4918.7kbits/s speed=18.5x
        Last message repeated 21 times
    [NULL @ 000001cbe022c020] FMO not supported
    [NULL @ 000001cbe022c020] reference overflow (pps)
        Last message repeated 186 times
    [NULL @ 000001cbe022c020] missing picture in access unit with size 526
        Last message repeated 54 times
    [mp4 @ 000001cbe0a9a020] pts has no valueB time=00:04:37.55 bitrate=4891.0kbits/s speed=18.5x
        Last message repeated 349 times
    [mp4 @ 000001cbe0a9a020] pts has no valueB time=00:04:49.23 bitrate=4855.6kbits/s speed=18.6x
        Last message repeated 319 times
    [mp4 @ 000001cbe0a9a020] pts has no valueB time=00:04:59.90 bitrate=4824.6kbits/s speed=18.7x
        Last message repeated 291 times
    [mp4 @ 000001cbe0a9a020] pts has no valueB time=00:05:09.65 bitrate=4794.6kbits/s speed=18.7x
    [mp4 @ 000001cbe0a9a020] pts has no valueB time=00:05:18.46 bitrate=4772.4kbits/s speed=18.7x
    [mp4 @ 000001cbe0a9a020] pts has no valueB time=00:05:28.63 bitrate=4743.2kbits/s speed=18.7x
        Last message repeated 352 times
    [mp4 @ 000001cbe0a9a020] pts has no valueB time=00:05:40.41 bitrate=4713.8kbits/s speed=18.9x
        Last message repeated 308 times
    [mp4 @ 000001cbe0a9a020] pts has no valueB time=00:05:50.72 bitrate=4688.4kbits/s speed=18.9x
    [mp4 @ 000001cbe0a9a020] pts has no valueB time=00:05:59.56 bitrate=4669.9kbits/s speed=18.9x
        Last message repeated 299 times
    [mp4 @ 000001cbe0a9a020] pts has no valueB time=00:06:09.57 bitrate=4648.4kbits/s speed=18.9x
        Last message repeated 92 times
        Last message repeated 173 times
    [mp4 @ 000001cbe0a9a020] pts has no valueB time=00:06:18.48 bitrate=4632.2kbits/s speed=18.9x
        Last message repeated 298 times
    [mp4 @ 000001cbe0a9a020] pts has no valueB time=00:06:28.46 bitrate=4614.4kbits/s speed=18.9x
        Last message repeated 261 times
    [mp4 @ 000001cbe0a9a020] pts has no valueB time=00:06:37.20 bitrate=4597.6kbits/s speed=18.9x
        Last message repeated 356 times
    [mp4 @ 000001cbe0a9a020] pts has no valueB time=00:06:49.11 bitrate=4577.9kbits/s speed=  19x
        Last message repeated 346 times
    [mp4 @ 000001cbe0a9a020] pts has no valueB time=00:07:00.69 bitrate=4562.7kbits/s speed=19.1x
    [mp4 @ 000001cbe0a9a020] pts has no valueB time=00:07:09.40 bitrate=4548.3kbits/s speed=  19x
        Last message repeated 145 times
    [NULL @ 000001cbe022c020] non-existing PPS 3 referenced
        Last message repeated 91 times
    [NULL @ 000001cbe022c020] sps_id 4 out of range
        Last message repeated 32 times
    [mp4 @ 000001cbe0a9a020] pts has no valueB time=00:07:18.44 bitrate=4533.5kbits/s speed=  19x
    [mp4 @ 000001cbe0a9a020] pts has no valueB time=00:07:27.19 bitrate=4522.0kbits/s speed=  19x
        Last message repeated 266 times
    [mp4 @ 000001cbe0a9a020] pts has no valueB time=00:07:36.10 bitrate=4508.8kbits/s speed=  19x
        Last message repeated 268 times
    [mp4 @ 000001cbe0a9a020] pts has no valueB time=00:07:45.07 bitrate=4497.2kbits/s speed=18.9x
    [mp4 @ 000001cbe0a9a020] pts has no valueB time=00:07:53.95 bitrate=4483.9kbits/s speed=18.9x
        Last message repeated 255 times
    [mp4 @ 000001cbe0a9a020] pts has no valueB time=00:08:02.49 bitrate=4472.7kbits/s speed=18.9x
    [mp4 @ 000001cbe0a9a020] pts has no valueB time=00:08:11.26 bitrate=4463.3kbits/s speed=18.9x
        Last message repeated 288 times
    [NULL @ 000001cbe022c020] missing picture in access unit with size 357
        Last message repeated 47 times
    [mp4 @ 000001cbe0a9a020] pts has no valueB time=00:08:22.51 bitrate=4450.2kbits/s speed=18.9x
    [mp4 @ 000001cbe0a9a020] pts has no valueB time=00:08:31.52 bitrate=4440.3kbits/s speed=18.9x
        Last message repeated 284 times
    [mp4 @ 000001cbe0a9a020] pts has no valueB time=00:08:41.03 bitrate=4429.5kbits/s speed=18.9x
    [mp4 @ 000001cbe0a9a020] pts has no valueB time=00:08:49.80 bitrate=4420.1kbits/s speed=18.9x
        Last message repeated 353 times
    [mp4 @ 000001cbe0a9a020] pts has no valueB time=00:09:01.61 bitrate=4407.4kbits/s speed=  19x
    [mp4 @ 000001cbe0a9a020] pts has no valueB time=00:09:13.39 bitrate=4396.2kbits/s speed=  19x
        Last message repeated 310 times
        Last message repeated 31 times
    [mp4 @ 000001cbe0a9a020] pts has no valueB time=00:09:24.84 bitrate=4386.2kbits/s speed=19.1x
    [mp4 @ 000001cbe0a9a020] pts has no valueB time=00:09:33.65 bitrate=4376.6kbits/s speed=19.1x
        Last message repeated 55 times
        Last message repeated 237 times
    [mp4 @ 000001cbe0a9a020] pts has no valueB time=00:09:43.46 bitrate=4368.0kbits/s speed=19.1x
        Last message repeated 267 times
    [mp4 @ 000001cbe0a9a020] pts has no valueB time=00:09:52.40 bitrate=4360.4kbits/s speed=19.1x
    [mp4 @ 000001cbe0a9a020] pts has no valueB time=00:10:00.91 bitrate=4354.1kbits/s speed=  19x
    [mp4 @ 000001cbe0a9a020] pts has no valueB time=00:10:09.92 bitrate=4346.5kbits/s speed=  19x
        Last message repeated 323 times
    [mp4 @ 000001cbe0a9a020] pts has no valueB time=00:10:20.73 bitrate=4337.5kbits/s speed=19.1x
    [mp4 @ 000001cbe0a9a020] pts has no valueB time=00:10:29.67 bitrate=4330.7kbits/s speed=  19x
        Last message repeated 321 times
    [mp4 @ 000001cbe0a9a020] pts has no valueB time=00:10:40.41 bitrate=4323.2kbits/s speed=19.1x
    [mp4 @ 000001cbe0a9a020] pts has no valueB time=00:10:49.29 bitrate=4316.3kbits/s speed=19.1x
        Last message repeated 300 times
    [mp4 @ 000001cbe0a9a020] pts has no valueB time=00:10:59.33 bitrate=4309.2kbits/s speed=19.1x
    [mp4 @ 000001cbe0a9a020] pts has no valueB time=00:11:08.28 bitrate=4302.6kbits/s speed=19.1x
        Last message repeated 293 times
    [mp4 @ 000001cbe0a9a020] pts has no valueB time=00:11:18.09 bitrate=4297.3kbits/s speed=19.1x
        Last message repeated 270 times
    [mp4 @ 000001cbe0a9a020] pts has no valueB time=00:11:27.13 bitrate=4292.0kbits/s speed=19.1x
        Last message repeated 314 times
    [mp4 @ 000001cbe0a9a020] pts has no valueB time=00:11:37.64 bitrate=4285.4kbits/s speed=19.1x
        Last message repeated 116 times
        Last message repeated 122 times
    [NULL @ 000001cbe022c020] sps_id 3 out of range
        Last message repeated 25 times
    [mp4 @ 000001cbe0a9a020] pts has no valueB time=00:11:46.51 bitrate=4281.2kbits/s speed=19.1x
        Last message repeated 207 times
        Last message repeated 136 times
    [mp4 @ 000001cbe0a9a020] pts has no valueB time=00:11:58.03 bitrate=4276.4kbits/s speed=19.1x
    [mp4 @ 000001cbe0a9a020] pts has no valueB time=00:12:07.07 bitrate=4272.3kbits/s speed=19.1x
        Last message repeated 198 times
    [NULL @ 000001cbe022c020] missing picture in access unit with size 244
        Last message repeated 1 times
        Last message repeated 59 times
    [mp4 @ 000001cbe0a9a020] pts has no valueB time=00:12:15.78 bitrate=4266.5kbits/s speed=19.1x
    [mp4 @ 000001cbe0a9a020] pts has no valueB time=00:12:24.75 bitrate=4261.8kbits/s speed=19.1x
    [mp4 @ 000001cbe0a9a020] pts has no valueB time=00:12:33.33 bitrate=4258.2kbits/s speed=  19x
    [mp4 @ 000001cbe0a9a020] pts has no valueB time=00:12:41.97 bitrate=4254.9kbits/s speed=  19x
        Last message repeated 339 times
    [mp4 @ 000001cbe0a9a020] pts has no valueB time=00:12:53.32 bitrate=4251.3kbits/s speed=19.1x
    [mp4 @ 000001cbe0a9a020] pts has no valueB time=00:13:02.82 bitrate=4247.1kbits/s speed=19.1x
        Last message repeated 301 times
    [mp4 @ 000001cbe0a9a020] pts has no valueB time=00:13:12.90 bitrate=4243.4kbits/s speed=19.1x
        Last message repeated 316 times
    [mp4 @ 000001cbe0a9a020] pts has no valueB time=00:13:23.48 bitrate=4239.3kbits/s speed=19.1x
        Last message repeated 334 times
    [mp4 @ 000001cbe0a9a020] pts has no valueB time=00:13:34.66 bitrate=4235.5kbits/s speed=19.1x
    [mp4 @ 000001cbe0a9a020] pts has no valueB time=00:13:44.97 bitrate=4231.3kbits/s speed=19.2x
        Last message repeated 328 times
    [mp4 @ 000001cbe0a9a020] pts has no valueB time=00:13:55.95 bitrate=4228.4kbits/s speed=19.2x
        Last message repeated 309 times
    [mp4 @ 000001cbe0a9a020] pts has no valueB time=00:14:06.29 bitrate=4226.1kbits/s speed=19.2x
        Last message repeated 377 times
    [mp4 @ 000001cbe0a9a020] pts has no valueB time=00:14:18.90 bitrate=4222.4kbits/s speed=19.3x
    [mp4 @ 000001cbe0a9a020] pts has no valueB time=00:14:30.25 bitrate=4221.6kbits/s speed=19.3x
        Last message repeated 344 times
    [mp4 @ 000001cbe0a9a020] pts has no valueB time=00:14:41.76 bitrate=4220.8kbits/s speed=19.3x
        Last message repeated 315 times
    [mp4 @ 000001cbe0a9a020] pts has no valueB time=00:14:52.30 bitrate=4219.6kbits/s speed=19.4x
        Last message repeated 252 times
    [mp4 @ 000001cbe0a9a020] pts has no valueB time=00:15:00.74 bitrate=4218.4kbits/s speed=19.3x
    [mp4 @ 000001cbe0a9a020] pts has no valueB time=00:15:11.42 bitrate=4216.5kbits/s speed=19.4x
        Last message repeated 325 times
    [mp4 @ 000001cbe0a9a020] pts has no valueB time=00:15:22.30 bitrate=4214.9kbits/s speed=19.4x
    [mp4 @ 000001cbe0a9a020] pts has no valueB time=00:15:34.71 bitrate=4212.1kbits/s speed=19.4x
        Last message repeated 7 times
        Last message repeated 130 times
    [NULL @ 000001cbe022c020] missing picture in access unit with size 560
        Last message repeated 179 times
    [mp4 @ 000001cbe0a9a020] pts has no valueB time=00:15:45.36 bitrate=4211.6kbits/s speed=19.5x
    [mp4 @ 000001cbe0a9a020] pts has no valueB time=00:15:53.80 bitrate=4209.6kbits/s speed=19.4x
        Last message repeated 3 times
    [NULL @ 000001cbe022c020] log2_max_frame_num_minus4 out of range (0-12): 101
        Last message repeated 246 times
    [mp4 @ 000001cbe0a9a020] pts has no valueB time=00:16:02.17 bitrate=4208.4kbits/s speed=19.4x
        Last message repeated 203 times
    [NULL @ 000001cbe022c020] non-existing PPS 11 referenced
        Last message repeated 61 times
    [mp4 @ 000001cbe0a9a020] pts has no valueB time=00:16:11.05 bitrate=4207.8kbits/s speed=19.4x
    [mp4 @ 000001cbe0a9a020] pts has no valueB time=00:16:19.76 bitrate=4206.8kbits/s speed=19.4x
    [mp4 @ 000001cbe0a9a020] pts has no valueB time=00:16:28.80 bitrate=4205.3kbits/s speed=19.4x
    [mp4 @ 000001cbe0a9a020] pts has no valueB time=00:16:38.44 bitrate=4204.5kbits/s speed=19.4x
    [mp4 @ 000001cbe0a9a020] pts has no valueB time=00:16:47.22 bitrate=4202.4kbits/s speed=19.3x
        Last message repeated 108 times
        Last message repeated 149 times
    [mp4 @ 000001cbe0a9a020] pts has no valueB time=00:16:55.86 bitrate=4201.3kbits/s speed=19.3x
    [mp4 @ 000001cbe0a9a020] pts has no valueB time=00:17:04.80 bitrate=4199.4kbits/s speed=19.3x
        Last message repeated 26 times
    [mp4 @ 000001cbe0a9a020] pts has no valueB time=00:17:14.71 bitrate=4198.2kbits/s speed=19.3x
        Last message repeated 82 times
    [mp4 @ 000001cbe0a9a020] pts has no valueB time=00:17:23.72 bitrate=4197.5kbits/s speed=19.3x
        Last message repeated 102 times
    [NULL @ 000001cbe022c020] non-existing PPS 15 referenced
        Last message repeated 169 times
    [mp4 @ 000001cbe0a9a020] pts has no valueB time=00:17:32.83 bitrate=4196.4kbits/s speed=19.3x
        Last message repeated 176 times
    [NULL @ 000001cbe022c020] non-existing PPS 4 referenced
        Last message repeated 187 times
    [mp4 @ 000001cbe0a9a020] pts has no valueB time=00:17:45.01 bitrate=4195.5kbits/s speed=19.3x
        Last message repeated 327 times
    [mp4 @ 000001cbe0a9a020] pts has no valueB time=00:17:55.95 bitrate=4194.0kbits/s speed=19.4x
        Last message repeated 290 times
    [mp4 @ 000001cbe0a9a020] pts has no valueB time=00:18:05.66 bitrate=4194.2kbits/s speed=19.4x
        Last message repeated 343 times
    [mp4 @ 000001cbe0a9a020] pts has no valueB time=00:18:17.14 bitrate=4192.6kbits/s speed=19.4x
        Last message repeated 379 times
    [mp4 @ 000001cbe0a9a020] pts has no valueB time=00:18:29.82 bitrate=4189.9kbits/s speed=19.4x
    [mp4 @ 000001cbe0a9a020] pts has no valueB time=00:18:39.46 bitrate=4187.3kbits/s speed=19.4x
        Last message repeated 4 times
    [mp4 @ 000001cbe0a9a020] pts has no valueB time=00:18:48.17 bitrate=4186.3kbits/s speed=19.4x
    [mp4 @ 000001cbe0a9a020] pts has no valueB time=00:18:56.68 bitrate=4184.9kbits/s speed=19.4x
        Last message repeated 251 times
    [mp4 @ 000001cbe0a9a020] pts has no valueB time=00:19:05.09 bitrate=4182.5kbits/s speed=19.4x
        Last message repeated 317 times
    frame=34638 fps=582 q=-1.0 Lsize=  590190kB time=00:19:15.70 bitrate=4183.5kbits/s speed=19.4x
    video:589824kB audio:0kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: 0.062102%
    And of course the video has the same problem.
    I tried a totally newbie move, and uploaded the raw file to youtube, and it got converted (the first 19 mins of it anyway - the video should be about 1 hour long), so I guess I'm missing something in ffmpeg to get it working. Worst case I'll just download the Youtube "fixed" version of 19min, which is better than nothing, but if I could somehow just demux to at least keep the original quality which is already pretty bad instead of downloading the youtube's converted one it would be great.
  2. Try avidemux, if it can open it try to output a file, if the file opened but is still broken try tools/check frames or tools/rebuild I and B frames in avidemux's menus. No guarantees of anything so work on a copy.
  3. avidemux cannot open it either. Shall google for tools you specified above. thank you.
  4. The tools are part of avidemux, but if it can't open it you can't use them. Poor phrasing on my part, sorry.
    edit: since it is an AVI maybe you can try to open it in Virtualdub, see if there is an error message or if it tries to rebuild the index.
  5. I'm a MEGA Super Moderator Baldrick's Avatar
    You could also try add the avi in mkvtoolnix / mkvmergegui and see if it can make a mkv out of it.
    And for virtualdub you probably need a h264 vfw decoder like the x264 VFW Codec.
