  1. Am I doing things correctly? I'm trying to convert 50i fps to 25fps for DVD.
    This is my Avisynth script:
    FFVideoSource("G:\test.mkv")
    Spline36Resize(720,576)
    SelectEven()
    I end up with 25fps interlaced. But is there a better method? Or is it really this simple? Thanks in advance.
    My video information:
    Video
    Format : AVC
    Format profile : High@L4.1
    Format settings, CABAC : Yes
    Format settings, ReFrames : 2 frames
    Codec ID : avc1
    Duration : 1h 9mn
    Bit rate : 10.0 Mbps
    Width : 1 920 pixels
    Height : 1 080 pixels
    Display aspect ratio : 16:9
    Frame rate mode : Constant
    Frame rate : 50.000 fps
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Interlaced
    Scan order : Top Field First
    Bits/(Pixel*Frame) : 0.096
    Stream size : 4.83 GiB (99%)
    Encoded date : UTC 1970-01-01 00:00:00
    Tagged date : UTC 1970-01-01 00:00:00
  2. Deinterlace 1080i to 1080p50 > resize to 720(704)x576p50 > re-interlace it to 720(704)x576i25 - this is best way to preserve source.
  3. Originally Posted by TheCatacomb View Post
    No. You forgot to deinterlace it. All you did was ruin it by resizing.
    You ended up with 12.5 frames per second (25 very ugly fields per second). Do you want to single-rate deinterlace it (and wind up with 25fps) or double-rate deinterlace it (followed by reinterlacing it, as pandy suggests)? If you do as recommended, something like this should work:
    Yadif(Mode=1)
    SeparateFields()
    SelectEvery(4,0,3)
    Weave()
  4. Thanks for the replies.
    [SIZE="1"]FFVideoSource("G:\test.mkv")
    Yadif(Mode=1)
    SeparateFields()
    SelectEvery(4,0,3)
    Weave()
    I had tried yadif deinterlacing before, but I was missing the SeperateFields() and Weave(). Now I understand what I did wrong. Thanks again.
  5. Formerly 'vaporeon800' Brad's Avatar
    Apr 2001
    Vancouver, Canada
    This is all assuming that you verified the source is truly interlaced, and not just an interlaced encode of progressive content.
  6. Originally Posted by vaporeon800 View Post
    I see interlacing in the original MKV whenever there's motion. However, this is a tv recording, so if you're asking if the original showing on television was progressive or interlaced, I don't know.
