I get this error message on windows 8.1 and cedocida installs anyway. It is just a warning saying that it is untrusted. You can check that it is installed in virtualdub in Video / Compression... . There should be a list of codecs. To avoid problems you should use 32 bits everything. 32 bits avisynth, virtualdub and codecs. So in your case cedocida_dv_only.inf , right click, install. Do not use the x64 folder. To open an avs in virtualdub 32bits you will most likely need a microsoft dll msvcr71.dll.
Results 61 to 72 of 72
Anon45Guest
Just concerned about the sound right now...
I tried my setup again, and it doesn't play/recorder over the right speaker.
Long story short, the earphone jack (on my camcorder) which I use for audio-out is monaural. The A/V jack is also monaural. So I can only output in mono with this camcorder. *sigh*
I had the same problem with my other camcorder and I thought it was broken; didn't think to read the manual. -
What's the problem? All you have to do is capture in mono, or capture in stereo and drop the empty channel.
Anon45Guest
No. If you have a 2-channel setup, the same sound will play to both speakers. With real stereo, the sound in each speaker can differ.
But the point is, your camcorder tapes are probably mono to begin with. They certainly are if the CCD-TRV58 was used to record them. Microphone operation mode: mono.
In that case, you can just fix the sound of the files you already have. -
Anon45Guest
Anon45Guest
Anon45Guest
I don't understand why the camera came with an A/V cable with Left and Right audio jacks, if there's only Left.
I don't think it did. I'm looking at eBay listings for the CCD-TRV58 and most of them include a 2-wire output cable (yellow for video and black for mono audio).
If you bought it used, the person simply included the wrong cable.
considering options for converting 8mm & hi 8mm to digital
By glen_s in forum Newbie / General discussionsReplies: 57Last Post: 21st Feb 2024, 16:52 -
8mm and Hi-8 to digital conversion
By Videorookie1953 in forum Video ConversionReplies: 3Last Post: 17th Aug 2015, 04:58 -
Pixelated Edge on Digital 8mm Playback. Please Help
By bradfordly in forum Newbie / General discussionsReplies: 3Last Post: 31st Dec 2013, 09:22 -
Best way to convert analog 8mm tapes to digital
By charliedog in forum Newbie / General discussionsReplies: 7Last Post: 29th Nov 2011, 03:15 -
Converting old 8mm tapes to digital..help!
By MrMister007 in forum Capturing and VCRReplies: 7Last Post: 4th Aug 2011, 23:59
