Guys I hope you can help me I'm trying to edit the Hosts file as an administrator and I can't figure out what I'm doing wrong https://forum.redfox.bz/threads/key-server-ips-instructions.68345/
I'm Running Windows 10 and UAC is disabled. I'm trying to follow "How to execute RUN as administrator" but I apparently don't understand how to do it.
http://www.howtogeek.com/howto/wind...administrator-from-the-windows-vista-run-box/
1. I've tried typing in "cmd" into the run box but that just opened up a prompt and entering "%systemroot%\System32\drivers\etc\hosts" does nothing.
2. I've tried typing in "%systemroot%\System32\drivers\etc\hosts"" into Windows 10 search bar and it brings up the file and asks how I want open it... I chose Notepad. I then edit the Hosts file and close to save it but it says I don't have administrator rights.
3. I clicked on "Run' and typed in "%systemroot%\System32\drivers\etc\hosts" and it goes directly to chose the program to open it but again it won't save it because I don't have administrator rights.
I've never attempted to edit the Hosts file before so I admit I don't have a clue what I'm doing. Can someone help?
Results 1 to 10 of 10
Just copy the file to your desktop...edit and save on desktop there no problem...then copy back and overwrite. Windows will ask on the return copy that you need administrator rights to copy and overwrite..you say ok. That is it..and soooo much easier.
'Do I look absolutely divine and regal, and yet at the same time very pretty and rather accessible?' - Queenie -
Oh thank you, thank you Ron! Jeez your way is so much easier even I can understand it! (Lol)
Type cmd in the search bar, right click on CMD.EXE, select Run As Administrator.
Try a program called HostXpert. I have tried it on all versions of Windows and works just fine. Just Google it and then download it. O, and it is free. Get it here at http://www.snapfiles.com, seems to be the best site.
If it feels good, do it. -
Thanks everyone! Ron's suggestion worked but for future reference glad to know there are many other ways to approach this!
You can also use "runas", in conjunction with a CLI batch/script/app and save that as a shortcut so that the shortcut (and only those you designate) always runs at elevated privileges.
Scott -
If you're trying to connect to the OPD server, then install AnyDVD 7.6.9.1 instead and remove any entries you've added to connect to the OPD server.
See here: https://forum.redfox.bz/posts/425742 or the entire thread: https://forum.redfox.bz/threads/key-server-ips-instructions.68345/ -
Looking for free website that hosts images
By vhelp in forum ComputerReplies: 2Last Post: 4th Nov 2015, 17:17 -
Legal ? about DVD ripping and sharing on file hosts
By sdsumike619 in forum DVD RippingReplies: 8Last Post: 28th Apr 2014, 18:41 -
How can i edit this file?
By muszty in forum EditingReplies: 7Last Post: 26th Sep 2013, 18:14 -
Selectively edit a MPEG file without re-encoding or file size reduction?
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 7Last Post: 3rd Jan 2013, 15:19 -
How do I edit h.264 video file with separate PCM audio file?
By FulciLives in forum EditingReplies: 4Last Post: 3rd Jul 2012, 17:22
