    Jan 2014
    Латвия
    Hello, Im using Sony ProType Titler to makу typewriting text effect and got one problem. I need to zoom in one word out of all text when its being typed (100) and make it bounce. How do I do that? When I do Pan/Crop and try zoom in and zoom out it affects whole text but I need to bounce only 100
    More details of problem are in my video (no, Im not promoting my channel on foreign forum ):
    https://youtu.be/Nb2kBVLhknY
  2. You need three versions of your text
    1. complete
    2. with a gap where 100 should be
    3. 100 only
    Do the write-on with the first version.
    Cut to the 2nd and 3rd version layered.
    Affect the "100" layer only for the bounce.
    You create the full version first so you have your spacing and size set, then remove the parts you don't want from 2 and 3.
    Remember, you're creating an illusion.
  3. Or place layer between original 100 and animated that cover original 100 during animation time
