I recently bought this card on ebay only to find out that there are no XP,2k drivers for it. Has anyone come in to this problem ,if so Is there a way around it?
Thanks!
Hi meandhers:Originally Posted by meandhers
You can get a driver here:
http://btwincap.sourceforge.net
kwagKVCD.Net - Advanced Video Conversion
http://www.kvcd.net -
Kwag, meant to earlier., thanks sooo much! worked like a charm, you don't know how many sites I've been to looking for drivers, looks like I should have come here first.
Thing is now, I get great Composite In captures, but can't get my TUner to work, in Virtual Dub under tuner settings it says locked--any advice./
Thanks again!! -
I used the following drivers/programs for my STB PCI TV Card and they worked great in win2k. 3dfx bought stb back in the day, so they made some beta drivers that actually work well with my old STB PCITV card. Here are the links:
win2k drivers:
http://www.voodoofiles.com/5523
win2k tv program:
http://www.voodoofiles.com/3507
tv program skin pack:
http://www.voodoofiles.com/3504
Capture Video/Audio from STB (DVB) with SCART in W7MCE through USB (EzCAP?)
By DIRKZELF in forum Capturing and VCRReplies: 7Last Post: 16th Jan 2012, 18:10 -
Black screen system32\DRIVERS\pci.sys Error with XP
By neworldman in forum ComputerReplies: 1Last Post: 8th Dec 2010, 15:34 -
Help Finding A High Quality Capture Card
By NMeade in forum Capturing and VCRReplies: 4Last Post: 24th Apr 2010, 20:00 -
Asus PCI PVR-210 FM drivers can't be found for XP ?
By MidnightMike in forum ComputerReplies: 1Last Post: 22nd Jan 2009, 09:05 -
Help finding ATSC STB
By TomTee in forum DVB / IPTVReplies: 30Last Post: 16th Sep 2007, 18:47
