having trouble working with this unknown sourced dvd video. Seems like it's 29.97 progressive encoded interlaced (see combing). Most 5th frames are a blend. Also some dupes present, but original video plays smoothly.
Tfm/tdecimate makes jerky video. TFM(), Deinterlacing or Bob/Srestore(29.97) plays smoothly but occasionally drops a frame. QTGMC/selectodd causes a dropped frame in the sample. Using "selecteven" avoids the drop in this sample, but creates one a minute or two later.
Also sometimes the video plays smoothly regardless of field order, sometimes it's TFF only.
tfm(order=-1) srestore(frate=23.976, speed=-25)
karma, interesting solution, but it creates a dropped frame a couple minutes later (in same spot I mentioned).
You may try messing with srestores(speed=##) setting. -25 is the most detailed/slowest while 25 is the fastest, with 9 being default. I changed it because 9 was not removing all the blends in your sample.
The portion that looks completely interlaced is just "phase shifted".
Frames 0-134 are normal, then there's a duplicate field that causes the phase shift, then there's another that causes 418+ to be normal again. When I say "normal", I mean besides the mentioned frame blending. -
In the first sample, a dropped frame can occur when the man hanging up his coat turns his head quickly. In the later scene (2nd sample here), another drop can happen as the same man's face becomes visible behind the other guy's head.
AVIDemux: Trouble initializing audio device (WinFF trouble too)
By Joker41NAM in forum Newbie / General discussionsReplies: 1Last Post: 1st Nov 2015, 04:12 -
Help deinterlacing/IVTC'ing VHS material converted years ago from film
By Mini-Me in forum Video ConversionReplies: 25Last Post: 4th May 2015, 13:46 -
How to IVTC
By jamespoo in forum DVD RippingReplies: 1Last Post: 29th Sep 2014, 18:39 -
where to apply deinterlacing and ivtc ?
By codemaster in forum DVD RippingReplies: 2Last Post: 30th Nov 2012, 15:40 -
AviSynth or GPU based deinterlacing / IVTC
By topsyturvy in forum Video ConversionReplies: 2Last Post: 7th May 2011, 09:07
