Hi, Just got this motherboard second hand and set it up in a case this weekend. After I had it all set up(6 sticks installed), I was getting 3 beeps(ram). I know the ram works cause I just had it in a older case and it worked fine. So here is what I have:
2 sticks of 2GB DDR2(533Mhz) 1.8v Non-ECC
2 sticks of 1GB DDR2(667Mhz) 1.8v Non-ECC
So far I am only able to get the 1GB sticks working. This is the first Dual Channel motherboard I have had so maybe I'm doing something wrong there... If I am unable to get all 6GB of ram working, Then I would prefer to get the 533Mhz ram working as I have more of it. I know product spec only says to only use 667 or 800 but I am assuming 533 still works. Am I wrong? Any help would be appreciated.. Thanks in advance!
try cleaning the contacts on the memory sticks with rubbing alcohol & Qtips.
blowout the memory slots with compressed air.
look up the manufacture of the motherboard to see if you have the right type
of memory.
Ram Backwards compatible?
By mason perales in forum Newbie / General discussionsReplies: 9Last Post: 12th Jan 2014, 22:18 -
ffmpegX for PowerPC (not Intel)
By cb678 in forum ffmpegX general discussionReplies: 11Last Post: 2nd Nov 2011, 23:14 -
intel wants to move AA onto the cpu
By deadrats in forum ComputerReplies: 1Last Post: 24th Jul 2011, 20:02 -
Intel Processors
By hardy in forum ComputerReplies: 6Last Post: 9th Jul 2011, 17:21 -
New Faster Intel chips
By redwudz in forum ComputerReplies: 1Last Post: 5th May 2011, 07:16
