Morning all! I am new to the forum. I found this forum while trying to search on how to convert MKV files. I am looking to burn them for Xbox 360. I have scanned this forum and I am overwhelmed with all the information I have found on everything! Great site!
Can someone point me in the right direction as to where I can find a way to burn downloaded movies to be played on Xbox 360?
Results 1 to 9 of 9
garryyjr, in the future please use a more descriptive subject title in your posts to allow others to search for similar topics. I will change yours this time. From our rules:
Thanks,Try to choose a subject that describes your topic.
Please do not use topic subjects like Help me!!! or Problems.
Moderator redwudz
And welcome to our forums.
Sorry bout that. I kinda rambled into asking for help. Didn't plan on it. I'll keep it in mind for future.
For Xbox360 you need it to be an MP4/AVI/WMV. For this MKV I would suggest having it remuxed into an MP4, and the simplest way to do that would be with MKVtoMP4. Just be sure you output AAC 2.0 (AAC Stereo) as Xbox does not like any AC3 audio nor 5.1 Surround AAC.
While it will probably re-encode the audio, it won't touch the video, just repack it. -
Thanks...
How and what you mean by repack it... Compress it? How should I go abouts doing that? -
I said repack because it's easier to understand, instead of remuxing. Your MKV contains an audio stream and a video stream, but those streams can be taken out and put into a MP4 without loss. Just Xbox 360 only likes AAC stereo in MP4s, or MP3 stereo in an AVI.
MKVtoMP4 does most of the work for you, just be sure it outputs AAC 2.0 (stereo). Your video is probably H.264 which could be put into the MP4 without re-encoding. Give it a try. -
I just converted a small 45 minutes video. Once I get back upstairs to grab a DVD i'll try it. Ill update when I get a yay or nay.
To watch a MP4 video file on the Xbox 360 I would transfer it to a normal USB memory stick (formatted to FAT32 <---important). If I had to use DVD, I would use Burnaware Free (Version 6.9.4 because newer version suck IMHO)
MKV to MP4 Variable Frame Rate - Xbox 360
By admiralspeedy in forum Video ConversionReplies: 7Last Post: 21st Mar 2013, 14:00 -
Hardcoding Subs to an MKV and streaming to XBOX 360 via Tversity
By RedFoxZERO in forum SubtitleReplies: 1Last Post: 28th Dec 2012, 10:22 -
How I convert TV shows to be compatible with Apple TV 2 and XBox 360
By Codestud in forum Video ConversionReplies: 5Last Post: 26th Aug 2012, 15:35 -
How to play MKV, MKV to AVI, MKV to DVD, MKV to Xbox 360 or Playstation 3
By Baldrick in forum Video ConversionReplies: 2Last Post: 8th Mar 2012, 03:45 -
Help to convert MPG to an Xbox 360 Format?
By lovelylisa in forum Video ConversionReplies: 7Last Post: 13th Jan 2012, 03:23
