I tried various things like FFmpeg, Premiere Pro, After Effects, and some sites, but they all sped up the video. MeGUI just doesn't work for me, and never has.
Basically, I want something like SVP. Bonus points if the program/method can output webm, but it's not necessary.
Results 1 to 10 of 10
In Premiere or After Effects just set up a 60fps sequence. As long as you have interpreted your source material correctly it will play at the proper speed. From there you have a number of interpolation options from simple duplicated frames to sophisticated optical flow.
Hmm, how do I do this? In Premiere Pro I get this screen, and I'm not sure what to do.. http://puu.sh/noybO/8d0eaa2b11.pngjust set up a 60fps sequence.
Also, I'm not sure where these options are supposed to be.From there you have a number of interpolation options from simple duplicated frames to sophisticated optical flow. -
But that still changes the length/speed/duration of the video.
I'll try MeGUI again. -
If you know about SVP and MeGUI already, you should also know about avisynth. You can use the InterFrame (motion interpolation) script for extra smooth results or simply change the frame rate.
If you don't know what I am talking about, check out the InterFrame thread http://forum.doom9.org/showthread.php?p=1486831Last edited by Evil_Burrito; 28th Feb 2016 at 11:49.
@Evil_Burrito: I just get this when opening the .avs: http://puu.sh/noEl2/4405b0e7af.png
And this when saving it: http://puu.sh/noEog/68c51494db.png -
I am not trying to be rude, but those errors have nothing to do with converting frame rates. You must learn how to use avisynth.
You probably didn't install all the required plugins (check the manual or comments in the script). Also, I recommend using the latest avisynth+. -
Generally you search for Motion Frame Interpolation - this is very complex and non solvable problem with classical math approach (perhaps well trained neural network will provide good results).
https://en.wikipedia.org/wiki/Motion_interpolation
How do I convert a video to 60fps without loss?
By fighuass in forum Video ConversionReplies: 3Last Post: 30th Dec 2015, 11:12 -
Want to Convert 120FPS to 60FPS
By OneLifeGuy in forum Video ConversionReplies: 3Last Post: 25th Mar 2015, 19:10 -
Can't figure out how to convert 60fps to 30fps with vdub/ripbot264
By 0-01 in forum Newbie / General discussionsReplies: 2Last Post: 20th Nov 2013, 08:20 -
How to convert from 60fps to 25fps to get continuous video?
By Bencuri in forum Video ConversionReplies: 236Last Post: 26th Aug 2012, 04:27 -
How do I convert 60fps to 30fps to halve file size?
By DigitalOxygen.ca in forum MacReplies: 33Last Post: 11th Jul 2012, 22:27
