To make matters worse you need a VPN to spoof a Japanese IP.
Here's my problem:
Trying to record/download the live stream of a tv station who streams online.
The stream keeps dropping/stopping or just flat out doesn't work.
I can find the m3u8 and have tried ffmpeg, livestreamer, and VLC, but they all drop/stop.
I noticed in AdBlock a new .key file keeps adding on to the list frequently. I've no idea what it means or what to do with it.
Also, sometimes I'm unable to select the highest video quality to get the m3u8 url in AdBlock. Is there a trick to get the m3u8 outside of waiting for it to load in AdBlock.
The video stream is technically form http://mcas.jp/#/channels/1 but they don't always have programs running so I've been experimenting with http://mcas.jp/#/channels/3 which runs a feed 24/7.
For ffmpeg I've tried:
For livestreamer I've tried:Code:ffmpeg -i "http://movie.mcas.jp/hls/v1/wn1_2.m3u8?Expires=1456714860&Signature=Oyd5HwKV6fwrRgmzrq98q2dPLECPsRqJUAdiV9I26I3XqupL4kLxxzUHVw6N34nwn2an8GzKqXQANa5HTObR1LkhozU5vZNGKfM8NmQRGFb7WIBjgKbtnI0fXzRhMcFmUCODxsFfjovtTF5OEU9-NWIBG3OWYl4ycfXqJnQxfMNjtGzLZe7l9CZdC4Skhgf8n687PoeUTOEmEHlLFF4JyAlx3ss9aSivarflQwb4zL1elvsJeJ~nZP5Jr0WeV59W4N1Rl69QsbQL7-xbTGXiWBo3on497LBwE0tWhtvpZl5eAQbaDj1xDfb4I1AzGSchcPqm5zKu60foWwgjvfqPGA__&Key-Pair-Id=APKAJUJRXEO57LGPCIQA" -c copy -f mpegts filename.ts
With VLC I've been selecting Open Network Stream, pasting the m3u8 url, and selecting Convert to save the file. It keeps disconnecting or dropping and sometimes doesn't connect at all, just giving me errors. I can't get a solid video.HTML Code:livestreamer "hlsvariant://http://movie.mcas.jp/hls/v1/wn1_2.m3u8?Expires=1456714860&Signature=Oyd5HwKV6fwrRgmzrq98q2dPLECPsRqJUAdiV9I26I3XqupL4kLxxzUHVw6N34nwn2an8GzKqXQANa5HTObR1LkhozU5vZNGKfM8NmQRGFb7WIBjgKbtnI0fXzRhMcFmUCODxsFfjovtTF5OEU9-NWIBG3OWYl4ycfXqJnQxfMNjtGzLZe7l9CZdC4Skhgf8n687PoeUTOEmEHlLFF4JyAlx3ss9aSivarflQwb4zL1elvsJeJ~nZP5Jr0WeV59W4N1Rl69QsbQL7-xbTGXiWBo3on497LBwE0tWhtvpZl5eAQbaDj1xDfb4I1AzGSchcPqm5zKu60foWwgjvfqPGA__&Key-Pair-Id=APKAJUJRXEO57LGPCIQA" best -o filename.ts
I really want to record some programs for a friend in the best video quality (i.e. I don't want to resort to laggy screen records) and get a solid video.
Please help? Any advice or insight as to what's happening is appreciated.
hi
try with livestreamer and hls:// instead of hlsvariant://
Code:livestreamer "hls://http://movie.mcas.jp/hls/v1/wn1_4.m3u8?Expires=1456714860&Signature=IqHZ-DMdNzVDdzaqM~leJmx1XKFtZAhiOvm5x8vpIsFQNwRPbC7eyNp-mGco46VUxlvON7KZX~1Qg1jRGZi3kKSN-Gc11oblyHCwcnU3OgSsJPzkftiI4Lioa90cH-WxPnFwInojEBOPcrY4Ya9qe5xWgrkBf5V1BN91SBmfvYgBFRidd3ZgzX6rYYQ1se9muuSHZhumWoAdrhtVDJgtn1IFI1HE33fyIbLzbj12PyXj3vkHk6UhWf2ni6BhNPx1SvQsQ08CzpeNC-4l~RPBXk1lKT5E2XKCLNxILx3Yy81d2myWPJZsFW0H6FXFEl8ajZfaOjTEfm32FH5alepF5g__&Key-Pair-Id=APKAJUJRXEO57LGPCIQA" best -o wheather-news.ts
Code:[cli][info] Found matching plugin stream for URL hls://http://movie.mcas.jp/hls/v1/wn1_4.m3u8?Expires=1456714860&Signature=IqHZ-DMdNzVDdzaqM~leJmx1XKFtZAhiOvm5x8vpIsFQNwRPbC7eyNp-mGco46VUxlvON7KZX~1Qg1jRGZi3kKSN-Gc11oblyHCwcnU3OgSsJPzkftiI4Lioa90cH-WxPnFwInojEBOPcrY4Ya9qe5xWgrkBf5V1BN91SBmfvYgBFRidd3ZgzX6rYYQ1se9muuSHZhumWoAdrhtVDJgtn1IFI1HE33fyIbLzbj12PyXj3vkHk6UhWf2ni6BhNPx1SvQsQ08CzpeNC-4l~RPBXk1lKT5E2XKCLNxILx3Yy81d2myWPJZsFW0H6FXFEl8ajZfaOjTEfm32FH5alepF5g__&Key-Pair-Id=APKAJUJRXEO57LGPCIQA [cli][info] Available streams: live (worst, best) [cli][info] Opening stream: live (hls) [download][wheather-news.ts] Written 2.3 MB (32s @ 61.4 KB/s)
EDIT: Never mind. Found out it was my connection causing the problems. Fixed.
Sorry to bring back an old thread, but I'm having issues again with the same site and a slightly different problem. The previous fix doesn't work now...
When I use livestreamer with hls:// it tells me
so I used hlvariant:// instead and I getHTML Code:[cli][error] Could not open stream: Attempted to play a variant playlist, use 'h lsvariant://http://movie.mcas.jp/mcas/wn1_2/master.m3u8?Expires=1476367260&Signa ture=ROCn4SaLkr3Ut45mFMhOCXchT674SI9deyX~snrVaDkNu656YL9Nz6YzrvX7KVLKcumsj-1lEJA tIKv0B2Jg3WZaqyXbWxmTDFFInWZpvynw4-o7wOyyIILSWlD0P~QjfiAIpGhbT1onS0Hsr3ODDx2UiFu 38-TSeXiBdjmhHqXqxpjB9nhh1Xoj1Sk0grllNgNRS4v4wHExwpgRxyzmt-WH3krQsQp9VQteizLI51i BQm859~tEoYVRZMVx8FlCLnPwPXIo6hMaMv3dY9FLd7Pjxx4PCEImI7v8tsS1A9fGQbSdE6hqt6SwPyf GhZrXGw-Vm~tXJvJkVzJuMi17KQ__&Key-Pair-Id=APKAJUJRXEO57LGPCIQA' instead
and that keeps repeating.HTML Code:[stream.hls][warning] Failed to reload playlist: Unable to open URL: http://movi e.mcas.jp/mcas/wn1_2/chunklist.m3u8 (HTTPConnectionPool(host='movie.mcas.jp', po rt=80): Max retries exceeded with url: /mcas/wn1_2/chunklist.m3u8 (Caused by <cl ass 'httplib.BadStatusLine'>: '')) [stream.hls][error] Failed to open segment 16882: Unable to open URL: http://mov ie.mcas.jp/mcas/wn1_2/media-ubxq5crrq_16882.ts (HTTPConnectionPool(host='movie.m cas.jp', port=80): Max retries exceeded with url: /mcas/wn1_2/media-ubxq5crrq_16 882.ts (Caused by <class 'httplib.BadStatusLine'>: '')) [download][testagain.ts] Written 668.4 KB (13s @ 51.1 KB/s) [ stream.hls][error] Failed to open segment 16883: Unable to open URL: http://movi e.mcas.jp/mcas/wn1_2/media-ubxq5crrq_16883.ts (HTTPConnectionPool(host='movie.mc as.jp', port=80): Max retries exceeded with url: /mcas/wn1_2/media-ubxq5crrq_168 83.ts (Caused by <class 'httplib.BadStatusLine'>: ''))
Help?Last edited by nobodyhome; 13th Oct 2016 at 17:30.
Tried both ffmpeg and Livestreamer w/o any luck. Help?
By nobodyhome in forum Video Streaming DownloadingReplies: 0Last Post: 20th Feb 2016, 22:55 -
Full range(0-255)colors of x264 doesn't work in FFMPEG-based softwares
By Stears555 in forum Video ConversionReplies: 1Last Post: 17th Apr 2014, 09:07 -
youtube m3u8 files ffmpeg doesn't work
By raz3 in forum Video Streaming DownloadingReplies: 6Last Post: 10th Sep 2013, 00:49 -
How to record part of live stream m3u8(30min)& save it as mp4 using ffmpeg?
By spiderMan007 in forum Video Streaming DownloadingReplies: 0Last Post: 18th Mar 2013, 17:54 -
new ffmpeg - my BATs doesn't work anymore - HELP! [SOLVED]
By CactusMan in forum Newbie / General discussionsReplies: 2Last Post: 1st Sep 2012, 13:24
