  1. I'm making a DVD. I made my own animated menu background, including my own "Play All" button.
    Then in DVDStyler, I placed the "Play All" button over where my button is and made the button invisible so only my button can be seen.
    However, when I burned the disc, I found that DVDStyler places a small white circle next to the "Play All" button. I don't want it to be there because the buttons don't appear immediately - my menu has a little animation first.
    Does anyone know how to get rid of the white dot? Or, even better, how to make the buttons wait a while before appearing so my animation can play first before the menu appears?
  2. Do you want an animated intro ending in a still menu,ie non-looping menu?
    I do this by using a Title as intro, grab the last frame and use this as still-menu background.
    Anyway, try using button=0; as pre-command for the menu and as cell command for the menu use button=1024; (or whatever button you want highlighted)
    EDIT: Just remebered: You can specify this directly in the menu property. Here buttons becomes visible after 4 sec:
  3. Thank you for your help Videoburger
    Yes, this is exactly what I want to do. But I don't know how to make title play first before the main menu appears?
    Sorry to sound ignorant but I have no idea what a pre-command or cell command are or where you enter them?
    [Attachment 35928 - Click to enlarge]
    That looks like it would work perfectly, thank you It's a shame I have to waste a DVD every time I want to test if it works properly, previews don't work on my computer. When I do a preview, my media player opens with an error saying something like "Can't connect to the internet".
  4. It's a shame I have to waste a DVD every time I want to test if it works properly
    Perhaps download the video "LearningCurve.mp4" from here.
    One way of doing this is DVD -> Options... and use First Play Command
Name:	Screenshot - 2_28_2016 , 3_18_47 PM.png
    and then as post command for the "intro" title use
Name:	Screenshot - 2_28_2016 , 3_19_07 PM.png
    (In case your media player is VLC it default to skip First Play Commands. It is shown here how to change the default setting)
  5. Thank you Videobruger, you have been really helpful
    I don't suppose you know anywhere where I can find a list of all the pre- and post- commands?
  6. I have another DVDStyler question while I'm here… Do you know which is quicker - to let DVDStyler recompress videos, or just set them to "copy"? I have burned a few discs using both methods and the time seems kind of random. Usually it takes about half an hour to burn a disc, but yesterday a disc took over 3 hours to burn - and that surprised me as the video was set to "copy" so I wouldn't have thought it required much processing. Weird.
  7. I don't suppose you know anywhere where I can find a list of all the pre- and post- commands?
    In DVDStyler you either select pre- and postcommand using a drop-down menu or you type them using a scripting language. If you havn't already you should start by reading this.
    With this scripting language you can - amongst other - access 16 General Purpose Registers setting their values and perform test on them. These registers are referenced by the letter 'g' followed by their number.
    As an example say you have a title with two audio tracks and two subtitle tracks then you could write a pre-command for that title using the register g5 to test which track to use like:
    if(g5==1) {audio=0;subtitle=64;} else {audio=1;subtitle=65;}
    So, there is as such no list of possible pre- and post- commands
    "Copy" is always faster and should be used if possible, ie the source files are DVD compliant. DVDStyler automatically uses "Copy" when it consider the source files for being compliant but is not infailurable in this respect as files with wrong GOP size or color space may be considered compliant. Ultimately the responsibillity is yours.
  8. Thank you so much once again! You have been really helpful, and that PDF is really helpful. DVDStyler really is an excellent program.
