ok i been trying for days with all my DLed avi movies to make them into mpg so i could then half them and make vcds.
i can view everything so far so i dont think its codec's as far as i can see anyhow.
in Tmpgenc i
l load my avi source movie it puts in the audio source the avi
i load my ouput like test.mpg
i load the vcd Pal template (because my avi was done with pal 25)
and i start the encode.
ALLways at 64% of What ever movie i try i get......
"lligal floating decimal point calculation order"
Now i found something on the site that suggest i should use vdub and make a audio .wav file for the audio souce to use in tmpgenc but i just did it still wont work:(
I despratly need help :( pls and thank you
do a search for illegal floating decimal...you'll find plenty of threads on this topic
It means you have some bad frames in the original file.
Install DivX Antifreeze find a link under tools and change in TMPGEnc. under Environmental settings: VFAPI plug-ins: DirectShow Multimedia File Reader priority to 1 by right clicking it and select Higher Priority
Read error with TMPGEnc
By MasterScreech in forum Authoring (VCD/SVCD)Replies: 2Last Post: 24th Jun 2010, 20:08 -
TMPGEnc Xpress 4.7.4.299 crashes at 50%; audio related
By CasanovaFly in forum Video ConversionReplies: 0Last Post: 28th Mar 2010, 23:20 -
TMPGEnc Read Error
By koberulz in forum Video ConversionReplies: 0Last Post: 6th Nov 2008, 22:44 -
DVD cannot be read after written - Pls Help
By its_me in forum DVD & Blu-ray WritersReplies: 6Last Post: 11th Jun 2008, 03:25 -
TMPGEnc DVD Author 3 no longer read .TS files?
By Nick Burns in forum Authoring (DVD)Replies: 3Last Post: 5th Nov 2007, 01:28
