Hello everyone,
I'm new to video.. I've downloaded an 18 GB mkv file and i would like to put this file to a Bluray disc and play it on my ps3. Can somebody please explain to me the steps of this procedure cause I can't seem to get a straight answer from the web. i know already that converting to AVCHD affects the quality of the video. So what are my options here- to have the ultimate experience of the bluray?Thank you in advance. sorry for my English, I'm from Greece!
oh. and the mkv file is 1280x720p H264 23.976 fps and has DTS audio 5.1
You can use tsMuxeR to put it into Blu-ray format. I'm not going to guarantee that it will work, because we have no way to determine the exact specifications of the video and audio in your MKV file. tsMuxeR will not change anything to make it compliant to Blu-ray specs. But this would be quick, and not degrade the existing quality of the video and audio.
Burn to a disc using ImgBurn and the UDF 2.5 file system. Personally, I'd use a BD-RE disc for testing purposes.
If it doesn't work, you can import the MKV file into BD Rebuilder and have it re-encode the video to match what is needed in Blu-ray format. In BD Rebuilder, click on File-->Import-->Video Files to get the MKV into the program. Set your target size to BD-25. -
Thanks a lot!i will try that.By the way, I don't need a bluray burner in order to play the file right?Is the ps3 capable?
If you are going to burn to a Blu-ray disc, you will need a Blu-ray burner. Blu-ray blank media will not burn in a DVD burner.
The PS3 should be able to play a Blu-ray movie, unless this particular movie has Cinavia protection. If it finds Cinavia in the audio, it will shut off the sound after about twenty minutes of play.
A PS3 with updated firmware has Cinavia detection. If the movie has the Cinavia trigger built into the audio stream, it is not easy to get rid of it, and no one offers a free program to remove it. You can't start with an MKV file with the DVDFab solution for Cinavia. I don't keep up with the DVDRanger programs, but they might have something that works with MKV's. I just wouldn't deal with that company for any reason.
Burning 2 movies to bluray disc using TSMUXER
By K.S.LEE in forum Newbie / General discussionsReplies: 3Last Post: 27th Jul 2015, 09:10 -
MKV To Bluray or DVD Disc
By maverickluke in forum Video ConversionReplies: 7Last Post: 21st Jan 2015, 15:04 -
Samsung F5100 cannot play MKV Files (size >4gb) burned on Bluray/DVD Disc
By K.S.LEE in forum Newbie / General discussionsReplies: 9Last Post: 5th Sep 2014, 01:34 -
How to convert a BluRay disc into a .MKV 720P file
By ioannis66 in forum User guidesReplies: 26Last Post: 22nd Oct 2013, 13:45 -
1920x800 MKV -> Bluray disc. Any good option?
By Asterra in forum Newbie / General discussionsReplies: 2Last Post: 18th Dec 2011, 21:48
