Closed Thread
  1. Hello All,
    I spent a couple days going through various post on A/V sync issues but most of them discuss how to fix after the fact. Is there a better tool to use for converting say a mp4 or mkv or avi even to DVD for playback on a set top DVD player that performs pretty well and not known for having sync issue? I'm just trying to do a basic conversion. I don't care about menus etc. I just want to same to video to DVD format.
    I know this is a problem that many people experience as well as I know lots of people successfully convert without issues. I'm sure the specs for the system being used to do the conversion plays into it as well. I'm using an Intel i5 3570 with 8GB RAM and 1GB on the video card. I've used many different tools but the latest was DVDFlick.
    Maybe sync issues is a standard issue that just has to be corrected which I've tried that too and it didn't fix the issue. I used the steps from here https://forum.videohelp.com/threads/311331-How-to-fix-audio-out-of-sync-in-a-DVD-withou...y-reconverting.
    If that is the case and it's just a matter of fixing the issue, can someone please point me to a step by step process that has consistently worked for them? I'm so desperate to resolve this that it doesn't matter if the tool is free or comes with a cost. Well, I guess based on the cost will determine how desperate I really am.
    I really appreciate any help that may be offered. I know this is probably one of those questions that folks say "oh no, not again". Please be patient...
    Thanks,
    Ronnie
    Mar 2008
    Post the mediainfo text report of your source file.
  3. Originally Posted by ronniej962 View Post
    Apparently, your 'sources' are downloaded and there's no telling if the guys that made them even knew what they were doing. You get what you pay for.
    Most people that use all-in-one programs don't use DVD Flick but AvsToDVD. There's no guarantee you'll fix the problem by using a different and better program, but at least the problem won't be occurring because of the program you use.
    I doubt it. The only difference the computer specs should make is in the time it takes to do the conversion to DVD.
    And as davexnet suggests, please provide the MediaInfo information of a typical file that winds up with the audio out of synch. Progressive audio asynch can be difficult to fix but the usual procedure is to first 'stretch' it so that its length matches that of the video. You might also try and compare the video length before and after with the audio length before and after to find out which one is the cause of the problem. It's almost always the audio at fault, though.
  4. Thanks Guys!
    I'm assuming this is what you're asking for:
    General
    Unique ID : 209767735154829392727993139891155365646 (0x9DCFCBD70BE10DFEB99FBB5F0791EF0E)
    Complete name : F:\DVD\Bridge of Spies 2015 1080p BluRay x264 DTS-JYK\Bridge of Spies 2015 1080p BluRay x264 DTS-JYK.mkv
    Format : Matroska
    Format version : Version 2
    File size : 3.56 GiB
    Duration : 2h 21mn
    Overall bit rate : 3 605 Kbps
    Encoded date : UTC 2016-01-20 05:34:42
    Writing application : mkvmerge v8.5.2 ('Crosses') 32bit
    Writing library : libebml v1.3.3 + libmatroska v1.4.4
    Video
    Format : AVC
    Format profile : High@L4.1
    Format settings, CABAC : Yes
    Format settings, ReFrames : 5 frames
    Codec ID : V_MPEG4/ISO/AVC
    Duration : 2h 21mn
    Bit rate : 2 850 Kbps
    Width : 1 920 pixels
    Height : 800 pixels
    Display aspect ratio : 2.40:1
    Frame rate mode : Constant
    Frame rate : 23.976 (24000/1001) fps
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.077
    Stream size : 2.81 GiB (79%)
    Writing library : x264 core 148 r2638 7599210
    Encoding settings : cabac=1 / ref=5 / deblock=1:-1:-1 / analyse=0x3:0x133 / me=umh / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=30 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=2 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=12 / lookahead_threads=3 / sliced_threads=0 / slices=4 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=5 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=50 / rc=2pass / mbtree=1 / bitrate=2850 / ratetol=1.0 / qcomp=0.60 / qpmin=1 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=62500 / vbv_bufsize=78125 / nal_hrd=none / filler=0 / ip_ratio=1.40 / aq=1:1.00
    Language : English
    Default : Yes
    Forced : No
    Audio
    Format : DTS
    Format/Info : Digital Theater Systems
    Mode : 16
    Format settings, Endianness : Big
    Codec ID : A_DTS
    Duration : 2h 21mn
    Bit rate mode : Constant
    Bit rate : 755 Kbps
    Channel(s) : 6 channels
    Channel positions : Front: L C R, Side: L R, LFE
    Sampling rate : 48.0 KHz
    Frame rate : 93.750 fps (512 spf)
    Bit depth : 24 bits
    Compression mode : Lossy
    Stream size : 763 MiB (21%)
    Language : English
    Default : Yes
    Forced : No
    Menu
    00:00:00.000 : en:Chapter 01
    00:10:29.462 : en:Chapter 02
    00:17:46.482 : en:Chapter 03
    00:22:09.828 : en:Chapter 04
    00:25:27.901 : en:Chapter 05
    00:31:18.209 : en:Chapter 06
    00:37:45.721 : en:Chapter 07
    00:45:29.268 : en:Chapter 08
    00:52:36.695 : en:Chapter 09
    01:00:39.427 : en:Chapter 10
    01:07:17.867 : en:Chapter 11
    01:16:52.399 : en:Chapter 12
    01:33:55.671 : en:Chapter 13
    01:45:41.752 : en:Chapter 14
    01:56:31.192 : en:Chapter 15
    02:07:20.549 : en:Chapter 16
    02:14:18.800 : en:Chapter 17
    canada
    Please do not ask for help on illegally downloaded movies,this is against forum rules,this thread is closed.
