So I used to use MPC HC a lot, then switched to MPC BE because I like the interface more. However, a problem has occurred on both. I have a big YouTube folder with a ton of files (hundreds), and some contain similar names and I listen to them while doing other stuff (like a music artist or something). So, in MPC HC/BE I had "play next in folder" under "after playback" selected. It went great for a long, long time, but then it started freezing my PC when switching files. Sometimes it happens, sometimes it don't, but it's way too frequent, and my only solution has been to restart my PC. I'm currently using Potplayer instead, which mostly works, although I've run into a different problem that I'll make a different post for. Anyway, Potplayer seems to be able to switch between files without freezing my PC, no problem whatsoever, so I'm not sure what the problem is.
Have you installed any codec packs or other video codecs recently?
Computer Freezes up completely while watching a 10 bit video on MPC-HC
By kairukun in forum ComputerReplies: 12Last Post: 24th Feb 2016, 01:56 -
My Videoeditor freezes and crashes, what can I do?
By hello0 in forum Newbie / General discussionsReplies: 5Last Post: 29th Dec 2015, 14:55 -
MPC-HC x64 Audio Freezes during playback.
By flex21 in forum Newbie / General discussionsReplies: 1Last Post: 12th Dec 2015, 09:19 -
MPC-HC 32-bit + madVR = frequent crashes in fullscreen
By Ygramul in forum Software PlayingReplies: 7Last Post: 5th Aug 2015, 09:35 -
Always +125% video/Frame/Zoom size MPC-HC/MPC-BE?
By tigerb in forum Newbie / General discussionsReplies: 6Last Post: 8th Mar 2013, 16:57
