I have a before/after to show.
But the before clip is 2-3 frames ahead. How can I resync it?
Either trim() a few frames off the beginning of the "before", or add frames to the beginning of the "after" clip (you can loop() a duplicate frame for example)
I thought as much. My issue was with the syntax and placement. My first few tests were failing. I needed to add .Trim() to the same line as AVISource.
It's works.
No, just doing something new. I'd never had a before clip not match the after. Apparently I cut it between pre and post. Oops.
And I'm still fighting that new desktop from time to time. Great fast/quiet system, but new Windows OS really do screw up the video workflows. Extra steps or workarounds are often needed.Want my help? Ask here! (not via PM!)
It must work... not sure if ffmpegsource allow to use filters from ffmpeg then time offset can be used instead adding physical frames but if it works then no sense to pursue perfection.
Well... OK - usually You are the One that provide answers
How to put two video clips side by side with VirtualDub and AviSynth?
By qingfeng in forum EditingReplies: 10Last Post: 1st Jun 2023, 08:57 -
Avisynth to ffmpeg - Comparison between two videos side by side
By mapg in forum Video ConversionReplies: 5Last Post: 17th Mar 2015, 13:00 -
3D stereo (side-by-side) to separate stream AVI converters pls?
By wpw007 in forum Video ConversionReplies: 8Last Post: 6th May 2014, 10:59 -
How to compare and edit individual frames of two videos side by side
By SushiSky in forum Newbie / General discussionsReplies: 8Last Post: 24th Jul 2012, 08:48 -
How Create ACHD side by side compatible with Panasonic 3D Cam and HDTV?
By castana in forum Video ConversionReplies: 7Last Post: 25th Jul 2011, 15:47
