Hi, I have an .avi file I'd like to edit in Virtual Dub but keep getting the message "decompressor needed for MP 42" something I've never heard of.
Much appreciate any help ...
Thanks in advance![]()
Results 1 to 17 of 17
Kept freezing? Did you exctract all files from https://www.videohelp.com/download/MediaInfo_GUI_0.7.82_Windows_i386_WithoutInstaller.7z with 7zip and then run mediainfo.exe. Then open your avi file. Change to view->text and ctrl-a and ctr-c(copy).
Or try https://www.videohelp.com/software/Virtualdub-AIO . It includes several video import plugins. -
Yes just as you said, only it couldn't find the .avi which was ready and waiting only the original MP4 file. Finally it kept freezing into an outline of a small box but with no text....?
Thanks I'll try your link next -
MP42 is Microsoft's old experimental Mpeg 4 Part 2 (like Divx, Xvid but not compatible) codec.
http://www.fourcc.org/mp42/Last edited by jagabo; 24th Feb 2016 at 08:59.
Thanks but I needed to use VirtualDub which has a manual frame by frame slider along the bottom using the left and right arrows on the keyboard, instead of using the mouse or at a very slow but automatic play rate....
VirtualDub uses VFW decoders. All you have to do install a VFW MP42 decoder and VirtualDub will be able to use it. That's why people have been giving you links to VFW MP42 codecs.
This was one of the sites I found....
http://www.moviecodec.com/video-codecs/mp42-decompressor-for-virtualdub-1670/ -
Maybe you have a 32 bit vs 64 bit problem? 64 bit VirtualDub requries 64 bit VFW codecs (of which there aren't many). 32 bit VirtualDub requires 32 bit VFW codecs.
Yes good point thanks as I've got 64 bit Win 7. I had thought of this but I'd read that using the 32 bit if possible, could avoid unnecessary problems later so preferable to use 32 bit which I finally chose.
Anyway the amazing thing is that it's suddenly started working just fine for some reason and is far, far superior to MPC and anything else by miles when using the slider actions across the bottom of the screen, as you can use the left/right arrows on the keyboard as I'd hoped. Quick single press for a single frame move, then obviously right up the scale to keeping your finger constantly down when it then runs at normal speed, so totally chuffed as I've been trying to sort this out for ages.
The only thing that's puzzling now is why it's suddenly started playing fine in MP4 which it refused to do previously ? And the reason why I'd had to convert it to .avi which I'd read somewhere was necessary to do first, yet even this wasn't being accepted either ?
Real mystery just wish I could pass on the reason why....
Thanks again all....
VirtualDub no audio decompressor
By hcs in forum AudioReplies: 4Last Post: 12th Oct 2015, 16:56 -
Convert Video to HD with AVC and MP42
By akhilrajau in forum Video ConversionReplies: 1Last Post: 24th Aug 2013, 21:28 -
Vorbis decompressor for virtualdub
By mkr10001 in forum AudioReplies: 2Last Post: 14th Mar 2012, 12:58 -
Cannot locate decompressor for H264
By Rogert in forum Newbie / General discussionsReplies: 2Last Post: 6th Oct 2011, 09:18 -
mp42 and 3gp4 - going crazy here... help?
By aiiro in forum Newbie / General discussionsReplies: 4Last Post: 30th Mar 2011, 16:12
