hello and thanks for reading this.
i am using vlc for apple ios. it does not support ac3 audio.
i have a bunch of videos in mkv and perhaps other formats that use ac3.
i need a way to convert the audio from ac3 to some other format.
i do not need to change the video, which looks fine.
so is there a way to quickly just change the audio to another format but not change the video.
not sure where to post this thread so i aplogize for being a newbie.
thanks,
and remember
the geek shall inherit the earth.
You can try Popcorn mkv audioconverter. Select the Audio output to AAC. It will not reconvert the video.
You could also use MKV2MP4. It will try change the mkv to mp4 without reconverting the video. You can choose to reconvert the audio to AAC also(it's on by default). -
VLC media player isn't good on win, the ios version is not worth to be mentioned.
MPC-BE, MPC-HC, ... for windows
And for iOS - get a better app:
I tried the first one and upgraded to the pro version.
https://itunes.apple.com/de/app/infuse/id577130046?mt=8
https://itunes.apple.com/de/app/infuse-pro/id893249751?mt=8
no need to reencode
re_sync audio in MKV files using VLC?
By cottage in forum Video ConversionReplies: 3Last Post: 8th Dec 2014, 12:13 -
VLC audio issues with large MKV files
By gerodive in forum AudioReplies: 2Last Post: 12th Aug 2013, 13:43 -
My bd mkv remux don't play smooth in vlc.
By botdvd in forum Video ConversionReplies: 1Last Post: 22nd May 2013, 02:04 -
VLC audio ac3
By muxado in forum AudioReplies: 0Last Post: 1st May 2013, 17:32 -
Video conversion on iOS??? (like ffmpeg for iOS???)
By shawntop in forum Video ConversionReplies: 8Last Post: 2nd Apr 2012, 12:57
