What sort of machine would you recommend me to build for 4K video editing? Is a Mac a preferable way to go as it has Thunderbolt Is an i7 processor adequate of should I aim for one or more Xeon processors. I would like to keep the cost down if possible. Another related question is do you think Windows 10 is any good for this or would a Linux system be a lot faster and cheaper
If you want to edit 4K now, for anything beyond the simplest cuts forget about keeping the cost down. You want the most powerful system you can find. Windows systems will always be cheaper than macs for the same capabilities.
Videoguys.com has good suggestions and you don't have to buy from them.
http://www.videoguys.com/blog/category/guides/diy-systems/ -
Share same impression (like videguys) that decent workstation is a best approach - HW selection should be in-line with software selection so first check what capabilities are for your software then buy best HW and be sure that your software will use it.
video editing software recommendations?
By mad hornet in forum Newbie / General discussionsReplies: 7Last Post: 23rd Feb 2016, 15:05 -
Recommendations for software for editing/authoring
By Yanta in forum EditingReplies: 6Last Post: 27th Nov 2014, 03:47 -
Recommendations converting and editing software
By madcheese in forum Video ConversionReplies: 15Last Post: 18th Oct 2012, 23:54 -
Video Editing Monitor Recommendations
By VideoTechMan in forum ComputerReplies: 41Last Post: 9th Oct 2011, 16:06 -
Video Editing Software: mkv, h264 & DTS Editing?
By techdls in forum EditingReplies: 8Last Post: 28th May 2011, 01:29
