Hi everyone,
I've been trying to add a dts audio track to a m2ts file that has 4 existing tracks (1× video, 2x audio, 1x ig). The problem Is that any tool I can find to mux the dts audio with this m2ts file (e.g. tsmuxer) doesn't recognise the ig track and so I end up with a muxed track without the ig track. Does anyone know whether this is possible?
Tony
That M2TS file is likely taken from an authored BD or AVCHD disc. Note: AUTHORED.*
The muxers used for authoring are capable of this, no others that I know of. And they aren't capable of muxing execpt as an element of intended BD/AVCHD output.
So, Re-author, remux, and re-extract?
*This is much like DVD, where MPEG2 DVD VOB muxers are capable of including LPCM audio and multi-angle video, whereas standard MPEG2 muxers cannot. -
Thanks for the reply.
Yes, the m2ts has been taken from an authored BD
Unfortunately, re-authoring with the original software is not an option and as I recall it wouldn't handle dts audio anyway.
I have saved the ig track to a .mnu file using BDedit, which I can then load into the free version of BD Fix and remux with the m2ts file (output from tsmuxer to include the DTS audio track) to produce a new BDMV structure. However, it appears that the limitations of the free version of BD Fix means that the output m2ts file does not contain the entire ig stream
It appears that there could be a way of doing this using existing software without having to re-author. The problem is that the versions of BD Fix that could achieve this are not free
Editing an audio track in an Mp4 video WITHOUT video data loss ?
By PeteV in forum Newbie / General discussionsReplies: 2Last Post: 11th Nov 2014, 14:46 -
Software for syncing and muxing audio track with video track?
By uranometria in forum Video ConversionReplies: 1Last Post: 21st Jul 2014, 02:52 -
Audio track from 25fps video with a 23.976 fps video
By cedworld in forum AudioReplies: 12Last Post: 22nd Apr 2014, 10:31 -
I need to mux an audio and video track of different lengths...
By Lathe in forum Authoring (DVD)Replies: 14Last Post: 8th Aug 2013, 22:22 -
Help
By manojkumar in forum Newbie / General discussionsReplies: 3Last Post: 19th Oct 2012, 21:06
