I've been trying to capture to 480x576, as this is the format required for SVCD's. For some reason I cannot understand, I just cannot capture at this res. I've tried varying all the settings, but it drops over 50% of the frames. However, I can capture at 720x576 at all settings with no frame dropping, even over an hour or so!
Whadisgoingon.....?! I can convert to 480x576 using TMPGenc, but this seems to defeat the point somewhat.....!
just experience talking here so I might be wrong.
if you are capturing an odd resolution, you will require alot more power. I have never tried this resoution, but I have tried other combinations well below 720*480 and they did not work, dropped frames out the yingyang, yet 704*480 or 720*480 is fine.
the resize on the fly is probably bogging down the hardware/cpu. -
Try lowering the motion estimation settings.
It's possible that you may be able to do 720x576 I-frame only or 0% motion estimation, but not 480x576 IBBP 100% motion estimation. -
I can do 720x576 at all settings....I frames only, B & P frames, 4bps to 15, 100% motion.
What Fiend says seems to make sense, so perhaps I'm better off sticking to standard res sizes, like 720x576 & the vcd settings......
Thanks.
I have a similar problem since I re-installed MMC 7.1. I cannot capture at CIF (352x288, 2.4MB/sec MPG) or full (720x576 8MB/sec MP2). They both drop the same number of frames. Howver I try Good quality (640x288, 6MB/sec MP2) and I have no problems.
Also it has no probs capturing at the Video CD setting which requires on the fly compression, so it clearly isn' t the speed of my system which is doing this.
Any thoughts?
ATI MMC 8.8 - capture driver not listed in registry?
By justin81 in forum Capturing and VCRReplies: 0Last Post: 21st May 2010, 10:13 -
Capture analogue with 720x576 has tiny horizontal bar at bottom
By ManUtdFans in forum Capturing and VCRReplies: 15Last Post: 21st Jan 2009, 13:12 -
ATI AIW X800GT - ANY capture software besides MMC?
By nbarzgar in forum Capturing and VCRReplies: 23Last Post: 18th Nov 2007, 01:24 -
(Completed): MMC capture results in 44100 sample freq instead of 48000.
By palouse in forum Capturing and VCRReplies: 14Last Post: 23rd Oct 2007, 15:47 -
Anyone using MMC with X800XL VIVO-only (no TV tuner or AIW) for capture?
By palouse in forum Capturing and VCRReplies: 4Last Post: 15th Aug 2007, 02:28
