Hey all,
I am running Windows 10 and with BD Rebuilder, I am getting some kind of strange pixelation in anything I encode whether it is to BD-25, BD-50, BD-9, etc. I checked and made sure the source is good. I am ripping with MakeMKV and encoding with BDRB. All of the dependencies say "Ok" when I use the built-in checker. FWIW, this is happening in other programs I've tried as well such as DVDFab.
Is there any way you guys can help me? At first I thought it might be a driver issue because it went away for awhile, then reared its ugly head again.
It's not happening in the source files, only the output files (before they are burned to the disc).
Do you have any codec packs installed like CCCP or K-lite?
Are you using Direct Show Source for Decoding/frameserving within BD Rebuilder or the X264 internal LAV filters?
Do you have the correct LAV filters installed from the BD Rebuilder bug report thread? And if you have Haali and FFDshow installed as well, did you install Haali and FFDshow first?
You might want to upload a small clip to show what is happening. The guys around here might be able to diagnose your issue quicker. You can cut out a section if you know the timing using tsMuxeR.
Are you having any other problems? Overheating? Slow-downs? SMART errors on the hard drive?
Is there anything unusual about the source files, such as interlaced VC-1? -
My PC does not seem to be showing any other issues. Strangely, I tried uninstalling BDRB and its dependencies and tried encoding a short clip with DVDFab and the issue is gone. It is strange because in the past, BDRB has worked perfectly fine. It did this once in the past, then quit. Now it's back to it again. I think Windows is playing around with some driver that's messing it up. I haven't changed anything in BDRB or its dependencies since last time other than uninstalling and reinstalling.
Maybe something isn't configured right. I'm going to play around with it and read the recommendations by the developer. Maybe there's something I missed there.
I will report back in a few days.Last edited by hogger129; 27th Feb 2016 at 12:28.
UPDATE:
I still cannot seem to track down what is causing it. I reinstalled and successfully did another job with it, no problems this time. It had to have been some kind of a configuration error.
EDIT: I should also mention I remember DVDFab experiencing this behavior one time as well, which is why I wonder if Windows is playing with some driver that is doing it. After all, Windows 10 doesn't tell you if or when it does updates.Last edited by hogger129; 27th Feb 2016 at 12:29.
It's still working fine after about a month. I think it's safe to say this is resolved for now. I don't think the issue is the program. I think it's some driver or a configuration issue. The thread can be closed. Thanks everybody who tried to help.
Question about BDrebuilder
By littlebase22 in forum Authoring (Blu-ray)Replies: 12Last Post: 12th May 2015, 17:56 -
Ripping with BDRebuilder
By tarzan54 in forum Blu-ray RippingReplies: 7Last Post: 26th Jun 2012, 21:58 -
Problem with BDrebuilder
By tarzan54 in forum Blu-ray RippingReplies: 10Last Post: 20th Jan 2012, 20:45 -
AMD CPU and BDrebuilder
By wulf109 in forum Blu-ray RippingReplies: 7Last Post: 18th Dec 2011, 15:19 -
PowerDVD 7.3 and new BDRebuilder
By dharper40 in forum Blu-ray RippingReplies: 4Last Post: 7th Sep 2011, 08:23
