Ηι.
How i can reduce the bitrare of any video file and most mkv without loosing the quality of the video?
Can i do that with the mkvtoolnix program?
If not is there any easy and quick program that can do that?
Closed Thread
You can't reduce the bitrate without decreasing the quality. You can't even re-encode at the same bitrate without losing quality.
It cannot re-encode anything.
Again, none that will not reduce the quality. But there are tons of programs that can re-encode with a lower bitrate: Handbrake, Xvid4PSP, XMediaRecode, AviDemux, VirtualDub, RipBot264, VidCoder...
Reduce video size
By simonrule in forum EditingReplies: 2Last Post: 28th Jul 2014, 12:17 -
How to significantly reduce size of an HD video with nearly same quality?
By oedipust in forum Newbie / General discussionsReplies: 47Last Post: 22nd Feb 2014, 21:54 -
Reduce Video Noise With ffmpeg command?
By sonicdeth in forum RestorationReplies: 21Last Post: 22nd Jan 2013, 16:37 -
How to reduce video bitrate of .m2ts and remux later into mkv?
By tanyo95 in forum EditingReplies: 5Last Post: 5th May 2012, 12:51 -
How to reduce video bitrate of a MKV file?
By doronb2 in forum Newbie / General discussionsReplies: 14Last Post: 3rd May 2010, 22:25
