  1. Hi,
    I've been trying to download a video from https://amebafresh.tv/official/2611
    I used adblock plus and found that the link to the Video file is https://movie.amebafresh.tv/movie/fresh2611/archive.m3u8 (not 100% sure)
    I tried:
    1) ffmpeg64 -i "https://movie.amebafresh.tv/movie/fresh2611/archive.m3u8" -c copy output.ts
    2) livestreamer "hls://movie.amebafresh.tv/movie/fresh2611/archive.m3u8" best -o output.ts
    However i keep getting http error 403 forbidden. Anyone can teach me how to overcome this problem and download the video?
  3. Thanks for the reply.
    I tried to use both the 32bit and 64bit ffmpeg (I am using 64bit windows 7) with the new code, but got a different error this time.
    ffmpeg32 -i "https://movie.amebafresh.tv/movie/fresh2611/006/576/playlist.m3u8" -c copy output.ts
    P:\>ffmpeg32 -i "https://movie.amebafresh.tv/movie/fresh2611/006/576/playlist.m3
    ffmpeg version N-78598-g98a0053 Copyright (c) 2000-2016 the FFmpeg developers
      built with gcc 5.3.0 (GCC)
      configuration: --enable-gpl --enable-version3 --disable-w32threads --enable-av
    isynth --enable-bzlib --enable-fontconfig --enable-frei0r --enable-gnutls --enab
    le-iconv --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --
    enable-libdcadec --enable-libfreetype --enable-libgme --enable-libgsm --enable-l
    ibilbc --enable-libmodplug --enable-libmp3lame --enable-libopencore-amrnb --enab
    le-libopencore-amrwb --enable-libopenjpeg --enable-libopus --enable-librtmp --en
    able-libschroedinger --enable-libsoxr --enable-libspeex --enable-libtheora --ena
    ble-libtwolame --enable-libvidstab --enable-libvo-amrwbenc --enable-libvorbis --
    enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx264 --enable-lib
    x265 --enable-libxavs --enable-libxvid --enable-libzimg --enable-lzma --enable-d
    ecklink --enable-zlib
      libavutil      55. 18.100 / 55. 18.100
      libavcodec     57. 24.103 / 57. 24.103
      libavformat    57. 25.101 / 57. 25.101
      libavdevice    57.  0.101 / 57.  0.101
      libavfilter     6. 34.100 /  6. 34.100
      libswscale      4.  0.100 /  4.  0.100
      libswresample   2.  0.101 /  2.  0.101
      libpostproc    54.  0.100 / 54.  0.100
    [hls,applehttp @ 0020f800] Failed to open segment of playlist 0
        Last message repeated 1433 times
    [hls,applehttp @ 0020f800] Error when loading first segment 'https://movie.ameba
    fresh.tv/movie/fresh2611/006/576/ts/0.ts'
    https://movie.amebafresh.tv/movie/fresh2611/006/576/playlist.m3u8: Invalid data
    found when processing input
    P:\>
    I am not sure what "failed to open segment of playlist" means. Can anyone offer any suggestions on how to solve this?
  5. Thank you so much for your help.
    I installed ffmpeg ver 2.85 and am now able to download the video without any problem.
