Thank you very much, jagabo.
Results 31 to 33 of 33
I've tried to export an mkv file but I can't. I go to: Video - Full Processing Mode. Then: Video - Compression. I choose x264vfw - H.264/MPEG-4 AVC coded and I click on Configure.
On Rate Control I choose: Multipass - 1st pass and 5750 bitrate. I choose the route for the stats file and for the Output file (mkv file). On Output mode I choose: File and VFW FourCC:h264.
Well, I click OK and OK again on: Select video compression. And, what should I do now? If I choose File - Save as AVI, I obtain an AVI file. How can I export the mkv file? and how can I use the stats file to do the Multipass -Nth pass? -
Set multipass first pass, save, then set multipass n'th pass, and save again. During the first pass the stats file is created, during the second pass the stats file is used to allocate bitrate. The file created in the first pass will contain no video; discard it.
To get an MKV file instead of an AVI file you have to use external muxers.
https://forum.videohelp.com/threads/367446-Virtualdub-External-Encoder-feature
Or just save as AVI then remux with mkvtoolnix later.Last edited by jagabo; 15th Mar 2016 at 09:37.
Still can't resize video
By steveeyes in forum Video ConversionReplies: 8Last Post: 16th Aug 2015, 21:44 -
Best method to resize an avi file downward
By loninappleton in forum Video ConversionReplies: 7Last Post: 31st May 2015, 13:09 -
any good reason (good excuse) not to keep AR when crop/resize to 720p?
By mkvonly in forum Blu-ray RippingReplies: 11Last Post: 3rd Mar 2015, 09:04 -
A bit confused with options to get good results with video and subtitles
By Valerc in forum SubtitleReplies: 18Last Post: 5th Jul 2012, 20:08 -
Anyone know of a good MP3 program to resize (make smaller) some files
By soulbug in forum Newbie / General discussionsReplies: 4Last Post: 28th Feb 2011, 16:03
