Results 1 to 30 of 33
    Feb 2016
    Europe
    Hi everyone.
    I've been trying to resize a video from 720x576 to 1280x720 with multiple methods but the results are always a blurred image. I want to know the best method to do it. I discovered this wonderful forum and I decided to ask here.
    I want to use an AVIsynth script with VirtualDubmod but I can't load the video (vob) on it. This is what I want to do with the video:
    Crop the black lines on the top and the bottom of the image, then Resize to 1280x720 but I want to obtain a sharp result.
    Obtain a Progressive video (because VideoSpec says: Interlaced - Top Field First) and finally Convert from 25 fps to 23.976 fps.
    Dec 2005
    Finland
    Install FFmpegSource to be able to load the video into Avisynth.
    Then the usual way to upscale would be something like this:
    FFMpegSource2("VIDEO1.vob")
    Crop(0,16,0,-16)
    NNEDI3_rpow2(2)
    LanczosResize(1280,688) # Assuming an aspect ratio of 1.85
    AssumeFPS("ntsc_film")
    There is no interlacing - use your eyes, tools just look at how the video is encoded, not what it actually contains.
    The video is however suffering from a lot of detail loss and blocking due to a low bitrate. There are deblocking and denoising filters that could additionally be used to reduce that problem.
    Feb 2016
    Europe
    Thanks a lot but I don't know how to install FFmpegSource. I went here:
    http://avisynth.nl/index.php/FFmpegSource
    Then here:
    https://github.com/FFMS/ffms2/releases
    And I finally download ffms2-2.22-msvc.7z. I unzip the file and copied ffms2.dll into Avisynth plugin folder. I opened VirtualDubmod, then I load your script and says:
    Avisynth open failure:
    Script error: there is no function named "FFMpegSource2"
    What can I do now?
  4. Copy FFMS2.AVSI into AviSynth's plugins folder too.
    Feb 2016
    Europe
    Thanks a lot. But with FFMS2.AVSI into AviSynth's plugins folder, same error:
    Then, I copied ffmsindex.exe into AviSynth's plugins folder and same error again.
    I don't know what to do.
  6. DECEASED
    Jun 2009
    Heaven
    Check the Registry and see what the Avisynth plugins entry says.
    Just as an example:
    [HKEY_LOCAL_MACHINE\SOFTWARE\Avisynth]
    "plugindir2_5"="c:\\program files\\avisynth 2.5\\plugins"
    Dec 2005
    Finland
    @Enrik
    Are all your programs and plugins either 32 bit or 64 bit? If they don't match, they won't work with each other.
  8. If you're running 32 bit AviSynth on 64 bit Windows the Registry entry will be under:
    [HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Avisynth]
    Make sure that the entry matches the actual installed location.
    Feb 2016
    Europe
    First of all, thanks to everyone.
    I'm using Windows XP Professional Service Pack 2, 32 bits. The registry says the same:
    What version of Avisynth and VirtualDub (or Virtualdubmod) should I use?
  10. DECEASED
    Jun 2009
    Heaven
    XP w/ Service Pack 3.
    VirtualDub: the latest one.
    VirtualDubMod: is dead.
    Avisynth: 2.6
  11. If the filters aren't loading automatically you can always load them manually in your script.
    LoadPlugin("C:\Program Files\AviSynth 2.5\plugin\ffms2.dll")
    import("C:\Program Files\AviSynth 2.5\plugins\ffms2.avsi")
    You'll probably have to load nnedi3 and any other required filters manually too.
    I'd use any recent version of VirtualDub and version 2.6 of AviSynth, both 32 bit. And all 32 bit filters.
    Feb 2016
    Europe
    Finally works with the final versions of Virtualdub, Avisynth and the 32 bits plugins! thanks a lot.
    Only 3 more questions:
    1-How can I improve the image quality? I mean obtain something similar to a real HD in 720p (maybe is not possible) but at least I would like to know how to use the deblocking and denoising filters on the Avisynth script to reduce the detail loss and blocking.
    2-The final size of the video is an AVI of 664 MB (with Direct stream copy) the initial size was 10 MB, is it normal?
    3-Is there any possibilities to save in Virtualdub as VOB, MP4 or MKV instead of AVI?
    Dec 2005
    Finland
    1) You should deblock the video before doing anything else. Then it could perhaps be stabilized, as this helps with denoising and looks better too. Then run a suitable denoising filter on it. Then it is time to upscale the result. Perhaps use a sharpen filter at the end, if it seems necessary. You can't get back details which have been lost, however.
    http://avisynth.nl/index.php/Deblock_QED
    http://avisynth.nl/index.php/Stab
    http://avisynth.nl/index.php/SMDegrain
    Just browse the wiki, there are many filters to choose from. But you will yourself have to try them out and see what you like best.
    2) If you just select "save as AVI", the video will be saved uncompressed, that's why it is big. Use Video -> Compression to choose another codec (if you have some installed).
    3) VirtualDub only really works with AVI files so it's best to use something else to encode other types of files. You can load Avisynth scripts with e.g. MeGUI.
  14. It will never look like native HD. The best you can hope for is to remove some of the MPEG block artifacts, reduce noise a bit, and enlarge the frame while keeping fairly sharp edges, without too severe oversharpening artifacts.
    I would start with Mpeg2Source("filename.d2v", CPU2="ooooxx") to get its deringing filter without its deblocking (which is too strong). Then use Deblock_QED() to reduce the blocking.
    Unfortunately the video already has fairly strong oversharpening halos. You can use dehalo_alpha() to reduce them but it also removes a fair amount of detail unless you fine tune it a lot.
    A temporal noise reducer will help but may also lose some low contrast details.
    There's a bit of projector bounce that you can reduce with Stab().
    This is overdoing it but should give you some ideas:
    Mpeg2Source("VIDEO1.d2v", CPU2="ooooxx", Info=3)
    Deblock_QED(quant1=30, quant2=20)
    Stab(4,4,4,4)
    Crop(4,16,-4,-16)
    Santiag()
    dehalo_alpha(rx=2.5, ry=2.5, brightstr=1.2, darkstr=0.8, lowsens=10, highsens=90)
    TemporalDegrain(SAD1=50, SAD2=35, sigma=2)
    Sharpen(0.3)
    nnedi3_rpow2(2, cshift="Spline36Resize", fwidth=1280, fheight=688)
    aWarpSharp(depth=2)
    Sharpen(0.3)
    GreyScale()
    Feb 2016
    Europe
    Thanks a lot, but what plugins should I have? I can't use the script:
    Mpeg2Source("c:\VIDEO\VIDEO1.d2v", CPU2="ooooxx", Info=3)
    Stab(4,4,4,4)
    Crop(4,16,-4,-16)
    Santiag()
    Sharpen(0.3)
    aWarpSharp(depth=2)
    Sharpen(0.3)
    GreyScale()
    I downloaded "dgmpgdec158" and I use "DGIndex.exe" to create a .d2v file and I obtain a file named "VIDEO1.d2v" and 4 more files: "VIDEO1.demuxed" and 3 ac3 files, I don't know if it is normal.
    Then, I put the following plugins on the Avisynth's plugins folder:
    DGDecode.dll
    masktools2.dll
    deblock.dll
    Deblock_QED_MT2Mod
    TemporalDegrain
    Dehalo_alpha_MT2
    And I have this error:
    Script error:there is no function named "mt_LutSpa"
    (Deblock_QED_MT2Mod.avsi, line 46)
  16. Originally Posted by Enrik View Post
    It might have to do with MaskTools2. Which version are you using? The DeBlock_QED readme says:
    # Changes 2010-10-16:
    # - Replaced 'relative' with the new 'mode' parameter in mt_LutSpa(), starting from MaskTools 2.0a45
    I believe you'll need that version or newer.
    However, it may also be that something's wrong with the way you're opening your video. Try this:
    Return Last
    Stab(4,4,4,4)
    Crop(4,16,-4,-16)
    Santiag()
    Sharpen(0.3)
    aWarpSharp(depth=2)
    Sharpen(0.3)
    GreyScale()
    If it won't open, then that's the reason.
  17. You need mt_masktools.dll.
  18. Originally Posted by jagabo View Post
    You sure about that? The DeBlock_QED page mentions only MaskTools2. Maybe he also needs that Microsoft Visual C++ 2012 Redistributable Package (x86 / x64) mentioned on the MaskTools2 page?
  19. Originally Posted by manono View Post
    You're right. Just the current masktools2.dll will work. Maybe I was remembering back when I had an older Masktools.
    Feb 2016
    Europe
    Thanks again. I used the script with Return Last:
    Return Last
    Stab(4,4,4,4)
    Crop(4,16,-4,-16)
    Santiag()
    Sharpen(0.3)
    aWarpSharp(depth=2)
    Sharpen(0.3)
    GreyScale()
    And when I load the Avisynth script on VirtualDub I get an error with a file: MSVCP110.dll. When I click OK all I can see is the original video without any changes.
    I've tried with this:
    AviSynth 2.6.0
    masktools2-x86.zip
    AviSynth+ x64
    masktools2-x64.zip
    And always the same error.
    I've installed Microsoft Visual C++ 2012 Redistributable Package (vcredist_x86.exe because I'm using Windows XP SP2 32 bits) and no luck.
    How can I solve that? Sorry for all those questions.
  21. MSVCP110.dll is a part of Microsoft's Visual C runtime library. I think it's this one:
    https://www.microsoft.com/en-us/download/details.aspx?id=5555
  22. Member
    Feb 2016
    Europe
    Thanks jagabo, and thanks to everyone but I'm going nuts with these errors. I've installed Windows XP Service Pack 3 and same error again and again. And now, two more errors with other files.
    When I try to load the Avisynth script I get this:
    This application has failed to start because d3dx9_30.dll was not found. Reinstall the application may fix that problem.
    This application has failed to start because MSVCP110.dll was not found. Reinstall the application may fix that problem.
    This application has failed to start because MSVCR110.dll was not found. Reinstall the application may fix that problem.
    Then, when I click ok, I see the same original video without changes. With these errors the script doesn't work.
    What's wrong? of course, I have installed vcredist_x86 and nothing has changed. Error, error and error.
  23. Lone soldier Cauptain's Avatar
    Jan 2006
    Brazil
    When I try to open the Avisynth script I get this:
    Download VCREDIST 2010 and Directx June 2010 executable.
    Claudio
  24. You need DX9 runtime: https://www.microsoft.com/en-us/download/details.aspx?id=34429
    Look in C:\Windows\System32\. Do you see MSVCP110.dll there? If not, you installed the wrong Visual C Runtime. Try an earlier or later version.
  25. Member
    Feb 2016
    Europe
    It's something incredible, on C:\Windows\System32 I see those files but I get the same errors again and again.
    I think I must format my computer, I can't fix those errors with any download.
  26. Didn't read whole thread - sorry for that but seem i don't see information that correct resize should be performed in linear RGB space.
    So pursuing perfection will require quite complex approach.
  27. Originally Posted by Enrik View Post
    Return Last
    Stab(4,4,4,4)
    Crop(4,16,-4,-16)
    Santiag()
    Sharpen(0.3)
    aWarpSharp(depth=2)
    Sharpen(0.3)
    GreyScale()
    ...When I click OK all I can see is the original video without any changes.
    Of course. The second line of your scrip is "Return last". That bypasses everything below that line. So effectively all you have is Mpeg2Source(...). Manono suggested that as a way to verify that Mpeg2Source() was working properly. And since you see the video, it is.
  28. Member
    Feb 2016
    Europe
    I have resolved the problem, all I had to do was delete the unnecesary plugins. I have no errors now. I will use the scripts again.
  29. Member
    Feb 2016
    Europe
    Finally, I used the next script:
    Mpeg2Source("C:\VIDEO\VIDEO1.d2v", CPU2="ooooxx", Info=3)
    LoadPlugin("C:\AviSynth\plugins\depanestimate.dll")
    Stab(4,4,4,4)
    Crop(4,16,-4,-16)
    Sharpen(0.3)
    aWarpSharp(depth=2)
    Sharpen(0.3)
    GreyScale()
    I have 3 questions.
    - With Santiag() (in jagabo's original script) I get the error: there is no function named Santiag. What is it? I can't find any plugin with that name.
    -Should I use the line "Sharpen(0.3)" twice?
    -How can I save the video with audio?
  30. Santiag() is an antialias filter.
    http://avisynth.nl/index.php/Santiag
    Import it with
    import("drive:\path\to\Santiag.avs")
    Whether or not you should run sharpen twice depends on your video. The idea above it to sharpen a little before upscaling, then sharpen again after. Of course, the same is true of all the other filters. For best results you need to tune the script for each video.
    I usually just mux the original audio with the new video after encoding.
