Further to my own comment there, I have only just discovered that if you upload a 4:3 clip to You Tube with those dimensions, then You tube will encode it as HD -- so there should be no need to add borders, to force it to 1280 x720.
If you upload as 768 x 576, then You Tube will encode as SD, and at a lower quality.
I'm not sure it was always like this? (YouTube is, for example, is fine with 50fps files these days... that certainly didn't use to be the case!)
In any event, a file uploaded as 960x720 appears to be look identical to the same file uploaded 'letterboxed' as 1280x720.
So, if you start with 960x720 clips - rather than 768x576 - then looks like there is no need to letterbox after all...
I've uploaded couple of short clips to illustrate the point.
Links below (from a VHS capture, so not very high resolution)
960x720 here: https://www.youtube.com/watch?v=t-QnGVOXqFU
1280x720 here: https://www.youtube.com/watch?v=fPNQdnGyq8U
Results 61 to 63 of 63
Thanks for update .. unable to do any tests as away with work at moment, appreciate the help.
I have an i5 machine 3570k this has 4 cores and 4 threads
What would I set under the MT command ?
I have been running using the SetMTMode(5,12) but see in many scripts SetMTMode(5,0)
I know that (5,12) = 12x logical cores however what does (5,0) mean .... does it have a specific meaning ? .... or does it simply make it run non-multithreadedLast edited by Tafflad; 29th Feb 2016 at 15:07.
Media choice DVD +R or -R
By Tafflad in forum Authoring (DVD)Replies: 4Last Post: 11th Dec 2015, 06:14 -
Converting Avi -> MP4 losless? and avidemux questions
By VideoNoob123 in forum Video ConversionReplies: 3Last Post: 6th Oct 2014, 06:50 -
Lossless to Losless audio conversion (Dolby Truehd<>PCM<>DTS-HD)
By maxrockpro in forum AudioReplies: 3Last Post: 3rd Mar 2013, 12:39 -
Choice of HD format
By Immortal25 in forum EditingReplies: 6Last Post: 8th Jul 2012, 00:28 -
need free program to quickly losless crop an mpeg2 740x480 to 720x480
By wolfdogg in forum Newbie / General discussionsReplies: 5Last Post: 13th May 2011, 17:49
