hello guys
i am sure this is comon problem
but i follow many settings in vegas to get good quality
in video
but still i get blurr
i read problem may be frame as i record in one frame rate and encode in other
i think this may be problem
i record in camtasia at 30fps, and encode in vegas at 29.970fps
please guys, can this be problem for blurry?
spasibo
Results 1 to 30 of 33
It could very well be the reason -- though it's more accurately called "blending." Do you have any particular reason not to keep the frame rate the same as the source?
i turned off resampling in vegas also
raw video is uncompressed avi, from camtasia at 30fps and fraps at 29.970
in the encoded video, should not the raw video recorded at 29.970 be crisp also, seeing i'm encoding at the same fps?
while the video at 30fps appear blurry?
or does the encode somehow screw everything up in the length of the full video, regardless of originals?Last edited by ricmetal; 17th Feb 2016 at 08:04.
If it's not blending, it might be chroma subsampling. If you've screencapped in RGB mode with fraps, but exported in some 4:2:0 format, the "sharp" color edges will become "blurry"
https://en.wikipedia.org/wiki/Chroma_subsampling
https://en.wikipedia.org/wiki/Chroma_subsampling#4:2:0
Look at the pictures - is that what you mean ? -
I suspect your blurriness if srom chroma subsampling. Are you talking about small colored text or other small colored objects? Video is normally encoded with chroma subsampling which blurs colors. For example a 1920x1080 RGB screen recording may be converted to YUV 4:2:0 resulting in the greyscale image (Y) being 1920x1080 but the colors (U and V) being encoded at 960x540. So small colored objects become blurry, especially small text with single pixel thick strokes. Example:
https://forum.videohelp.com/threads/319360-DVD-LAB-PRO-color-map?p=1977264&viewfull=1#post1977264 -
im sorry but the images in the wiki all look very similar to me
here's is a sample of the encoded video from the 30fps raw video recorded in camtasia. no blur.
here's a sample of the encoded video from the 29.970fps raw video recorded in fraps. major blur. especially noticeable on the text.
weird turn of events it seems
the second screenshot, was recorded at the same fps (in fraps) as the encoded video's fps, and is blurry
the first screenshot, was recorded at 30fps (in camtasia), a different fps as the encoded video, and does not look blurry
so is the difference from 30 to 29.970 not enough to create a visible distinction?
what does this mean overall?
does this have to do with the rgb settings? in fraps, i recorded the video with the lossless RGB capture de-selected btw.
and how do i get camtasia to record at 29.970?
it only allows me to input 3 digits, with no symbols like a coma
i found the setting in the screen recorder, then: tools, options, inputs.Last edited by ricmetal; 17th Feb 2016 at 09:07.
The kind of blur that Vegas would cause with resampling would only effect moving objects and will look like double exposures.
The blurring from chroma subsampling will happen with colors in any video. Your game image seems to have more blur than I would expect from that though. What does the original image look like? Was the game being played at 1920x1080? And captured at 1920x1080? -
this is an image of the original video recorded with fraps
https://i.imgsafe.org/b78e110.jpg
as you can see it looks perfect
the video was recorded in 1920*1080, so is the resolution of the game..
these are my vegas settings - just as a point of interest
https://i.imgsafe.org/0dd026c.png
the bitrate is over the top, i know, but i tried to get rid of the blur by messing with settings.Last edited by ricmetal; 17th Feb 2016 at 10:36.
let's see:
my project properties in vegas is 1920*1080
https://i.imgsafe.org/ad5d04e.png
my vegas render settings is 1920*1080
my original fraps video is 1920*1080
https://i.imgsafe.org/41a0285.png
the final video's setting is 1920*1080
https://i.imgsafe.org/3a23ec2.png
i wouldn't know where else i could be down sizing...
edit: i don't know if i started with a 720p project, but i assume i can change the project's properties to another resolution without interference, or no?Last edited by ricmetal; 17th Feb 2016 at 11:17.
I'm not sure what's going on and why only the fraps footage is affected (despite it being the correct frame rate) .
(It's not a frame rate / smart resampling issue because only some frames are blended, and you said you disabled it anyways)
What do the sections with fraps footage look like within vegas's preview before exporting ? Have you tried disabling GPU/CUDA on export and/or tried other export formats ? Try uncompressed AVI for example (just render a small section for a quick test). And what does mediainfo (view=>text) report on the exported file that looks bad? -
oh, the preview video actually looks like crap. i never noticed it because i had the video resized to fit and looked way better.
it looks pretty much like the exported video.
no, wait..
https://i.imgsafe.org/617721d.png
i don't know what that preview button does, but setting it to anything else other than preview, full, gives that blur we see in the exported video.Last edited by ricmetal; 17th Feb 2016 at 16:11.
Did you have the preview set to full / best quality ? If the preview is already "crappy" then the problem likely occurs before exporting (all the things like encoding settings etc... probably aren't relevant)
If you start a new project , 1920x1080 progressive, and drop some fraps footage onto the timeline, look at the preview set on best - what does it look like ? What if you import that fraps footage into something else like vdub ? -
Can you answer the other questions (I edited the post above, maybe before your last reply)
Not sure why if it works fine in a new project...that suggests it's a project specific problem. Check to make sure you haven't done something like scaling, blur filter etc...Try reloading the footage (you can even move them or rename the folder and relink them to force vegas to re import)
Tackle one problem at a time
. If the preview is accurate and already blurry, then no export settings tweaking will make much of a difference . That type of blur on export might be different - the chroma subsampling or "color blurring" that was mentioned earlier depending on what you exported
yeah, but i rather not have to reload stuff just yet, it sounds like my plan b, even because,
i think there is a discrepancy between vegas' project settings and the video,
because when, in a new project, i adjust vegas' project settings to match the fraps video,
the preview looks fine
but,
if i don't match the project settings with the fraps video,
the preview looks like crap
there are a lot of settings to be seen
one that pops out right in the main ui is
something to do with the resolution:
the video says 1920*1080*24
while the preview and project say: 1920*1080*128
and there's a display info on resolution that says 1920*1080*32
these are different numbers that i don't like
what are they and do they make any difference?
https://i.imgsafe.org/dbd3f25.png -
32 and 24 aren't relevant, it's just RGB24 and RGB32 (one with alpha channel) .The 128 is bizzare - not sure what that is
But your field order= upper field first means it's being deinterlaced. That for sure will cause it to look blurry. Make sure the clips are interpreted as progressive (right click the clip, properties) -
smrpix, i do do that, but the files in the media section dont get the settings from the project.
poison, you said i can change the frame rate in camtasia to 29.970.
how do i do that?
i'm the settings (in the recorder) "tools", "options", "inputs", "screen frame rate" but it won't allow me to insert this specific value..Last edited by ricmetal; 20th Feb 2016 at 16:42.
Video going from blurry to real sharp back and forth
By killerteengohan in forum RestorationReplies: 3Last Post: 14th Aug 2015, 13:50 -
HDR-SR7 Shaking and blurry video
By Dave Blaha in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 25th Jul 2015, 02:51 -
Blurry video |Sony vegas|
By Benjiron in forum EditingReplies: 0Last Post: 9th Jun 2013, 20:33 -
Blurry motion using AVS4YOU Video Editor
By CaspianCanuck in forum Video ConversionReplies: 2Last Post: 16th Jul 2012, 23:22 -
Video is blurry on computer but clear on HDTV, how can it happen?
By Bencuri in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 55Last Post: 26th May 2012, 11:48
