Hi guys,
I've used Vegas Pro 10.0 numerous times.. and never had a problem. Unfortunately yesterday I opened one of my most recent projects and found out that there's some kind of weird problem with the software(refer to screenshots)
If I open the "Video Media Generators" all the tabs... Edit,Placement,Properties and Effects don't display all the attributes/settings ?
Same happens with "Video Event FX" and any effect that I decided to add.. I simply can't see all the options.
I've re-installed the program 3 times.. reset it to default settings.. but nothing seems to work.
Solution ? Thank you.
Screenshots:
Video Media Generators(Text) : http://puu.sh/naJh4/b68dfd908c.png
Video Event FX(Gaussian Blur) : http://puu.sh/naJeR/d1f52a98eb.png
Yep. That's a weird bug.
WHen did it work/look okey?
Have you upgraded windows recently?
Installed any other software recently?
New graphic drivers?
Any similar problems with other software? -
probably will not work, but i've seen a few programs show me empty modals, only to fix themselves on resize (if possible)
might be worth a shot -
Hi there guys, sorry for not replying sooner. Had tons of things to do. To test whether it's from the software itself or not.. I installed it on my laptop and it works completely fine. This tells me that it's more likely to be a Windows issue with window scaling or something ? any suggestions ?
Help me!!!!! (SONY VEGAS PRO 13.0)
By Tengzy in forum Newbie / General discussionsReplies: 4Last Post: 1st Jul 2015, 23:48 -
Weird border covering 1/4th of preview screen (Sony Vegas Pro 11)
By nuckingfuts in forum EditingReplies: 10Last Post: 6th Jul 2014, 15:59 -
Sony Vegas Pro 13
By budwzr in forum EditingReplies: 4Last Post: 21st Apr 2014, 20:49 -
Difference in price between Sony Vegas Pro 11 & Sony Movie Studio Platinum
By Ghost Dust in forum Newbie / General discussionsReplies: 8Last Post: 11th Feb 2013, 13:42 -
Sony Vegas Pro 10
By av.sorong in forum EditingReplies: 16Last Post: 9th Oct 2011, 13:27
