Running 64 bit Win7 with Adobe Flash Player. All browser extensions disabled, hardware acceleration unchecked. Baud rate > 20 Mbps. CNN videos do not play.
CNN plays next door using same ISP running a more restrictive Win7; we're both in a nursing home with the same Wi-Fi. Both PC's were tested with Chrome.
Win7 and Baidu firewall On/Off makes no difference.
Videos from CBS, NBC, ABC & FOX play.
Text from CNN readable.
CNN videos play in Safe-Mode
Google news has a CNN a video that plays in the browsers and Adobe Flash.
Conjecture ; problem caused by Adobe Flash; in CNN it enables hardware acceleration [right click spinning square > inspect > settings shows it's enabled and cannot change]. Previously, I had disabled hardware acceleration both in the browsers and in Adobe Flash.
Chrome uses a built-in flash player so try Firefox or Internet Explorer and see if you get same problems.
Tried Safari - same problem. However, with the Tor browser the CNN videos play! Does this mean there is a fix for Chrome or Firefox?
Have you looked in Control Panel under Flash Player to update it? (considering W7 still has this - I'm still on XP)
2 videos playing right next to each other
By Fr3aKeD in forum Newbie / General discussionsReplies: 3Last Post: 2nd Oct 2015, 10:35 -
CNN/HLN/truTV can't work with Linux?
By RedPenguin in forum Video Streaming DownloadingReplies: 3Last Post: 24th Sep 2012, 20:43 -
Problems Playing Videos on Premiere Pro 5.5
By IggyLites in forum Newbie / General discussionsReplies: 4Last Post: 23rd May 2012, 11:20 -
NO VIDEOS are playing in my PC
By swalih in forum Newbie / General discussionsReplies: 28Last Post: 22nd Mar 2012, 09:33 -
Playing Videos on Mac vs PC
By Alienated in forum Software PlayingReplies: 5Last Post: 11th Mar 2012, 08:31
