So I'm having quite a weird problem with TSmuxer.
It will take a file on drive A and it will demux it to drive A.
However, if I take files from any drive and try to mux to TS to drive A, TSmuxer says "parameter is incorrect" and stops. I get "Tsmuxer finished with error code -1."
However, if I try to mux to M2TS, it works fine.
Any ideas? I've checked permissions to make sure that everything was correct. I'm running it as an admin. I don't know what the problem could be.
Results 1 to 15 of 15
will it MUX a file to TS on drive A
or is this a mux only m2ts and not to any TS on any drive -
Very strange problem. So it can mux/output to drive A but not ts files.
Can you copy .ts files to drive A from windows explorer? -
Are you using the drive letter A as a generic nomenclature? I ask because drive A used to be the nomenclature for a floppy drive in the PC world.
Extraordinary claims require extraordinary evidence -Carl Sagan -
Yup. I can move or copy or do whatever I need to. The only problem is that tsmuxer won't mux to TS on it. Everything else is fine.
Meaning?
NSF. Everything I have is NSF. There are singular HD files on there that are 50GB+
Correct.
Is the problem drive an external USB drive?
There were past reports of tsmuxer problems while muxing to external USB 3.0 drives. Not sure if it was a tsmuxer or Windows bug. Easy solution was to mux to an internal drive and then move the output to the external drive. -
Have you tried a different simple output file name and output directory in case it's a naming error or conflict.
There's not much to do but then I can't do much anyway.
TS Muxer won't mux 1080i h264 with AC3 file - help!
By VideoFanatic in forum Video ConversionReplies: 2Last Post: 28th Dec 2013, 15:10 -
Tsmuxer won't accept more than 1 file at a time?
By jbitakis in forum Video ConversionReplies: 10Last Post: 7th Dec 2012, 11:21 -
TSMuxer crashing error code -3 TSMuxer GUI
By petermg in forum Authoring (Blu-ray)Replies: 2Last Post: 30th Nov 2012, 16:21 -
DVD player won't recognise hard drive
By Danny01boy in forum Newbie / General discussionsReplies: 4Last Post: 13th Aug 2011, 22:43 -
MKV2VOB & TSMUXERGUI Won't Mux Entire Video
By FordGTGuy in forum Video ConversionReplies: 10Last Post: 11th May 2011, 13:14
